what control surface
wondering what options are out there other than the C24... currently i use an avalon for my mic pre and go directly into my 96 io with everything else... i am looking for something to route my audio into my 96 io mainly for volume control going in without "coloring" the sound... any suggestions
Re: what control surface
I would NOT recommend the Mackie Universal Control. I own one and it loses connection after being connected for ~5 min....every 5 minutes. It just never stays connected. I have one of the older models (before the newer faders). I don't know if there is anything really different.
You have the Command 8, Euphonix Artist Control, There's a behringer unit for around $200, and the PreSonus FaderPort.
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions) |
i need inputs and out puts command wont work
You won't really be getting "inputs and outputs" through the C|24. The C|24 has 16 so-so preamps and that's it (within the context of this conversation).
Do a little research on gain staging. You need to adjust the level coming out of whatever you're plugging in to the 96 I/O. And as a general rule, you should not use the Pro Tools faders to adjust input gain. Set them to "0", then adjust whatever is going into the 96 I/O until you're peaking at -15, -18, whatever...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
uh the c24 has inputs and outputs..."adjust the level of whats going in to the 96" u dont say?? never would have thought of that... was just looking for some kind of volume control without using a mixer... i dont like to color the signal just wanted a line of defense before going in to the 96 didnt know i need to research gain staging for that but thanks for the tip buddy
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
no i like my 96 io... i cant afford a 192 right now but i would like an affordable trim section
You will realize how much you don't like that 96 i/o when you upgrade, and my point is, right now, that variance is very small.
the varience would be another 1200 which i dont have... but since u dont like to answer the actual question u can be excused now
Barry, don't waste your time trying to help this guy. He was on here before in another thread (at least one, maybe more) asking for help and insulting everyone that tried to help. He's an arrogant loser.
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24; PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R |
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
D-Control Es32 Control Surface No Sound from Headphone outputs | mark007 | Pro Tools TDM Systems (Mac) | 0 | 02-08-2012 07:03 PM |
Digi 003 Control Surface Mackie Control Mode | ctmusicman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-23-2008 07:23 PM |
Mackie Control Universal or Tascam 1082 for control surface? | anders | Pro Tools TDM Systems (Mac) | 5 | 05-28-2007 06:12 AM |
