Old 04-25-2022, 01:29 AM
TrentWilliams TrentWilliams is offline
Default PT Video Peripheral Advice BM vs AJA
Hey everyone,
I’m looking for some advice on video peripherals.
I ordered in a Blackmagic Ultrastudio 4K Mini last week (haven’t paid for it or picked it up yet), in the week since I’ve been doing a little more reading and found some less than favourable comments on the Blackmagic system. I chose the Ultrastudio initially to save a few dollars after checking out the AJA IO 4K Plus box, but now I’m thinking I should change the order to AJA.
The last insightful thread I found on this was from 2018, so I thought I would start a new one to check in on the current state of things in 2022.
Any insight any of you have would be appreciated,
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 04-25-2022, 06:54 AM
Default Re: PT Video Peripheral Advice BM vs AJA
I am using BM driver 11.4.1 with zero issues but I'm on an Decklink SDI.
F.
Old 04-26-2022, 02:41 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I am a big fan of Aja.
I had nothing but headaches with BM and all their drivers hassle.
The Aja just works. Their support is superb and their drivers are frequent and current.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 04-26-2022, 02:48 AM
Cheesehead Cheesehead is offline
+1 for Aja.
I initially bought Blackmagic but had driver issues.
Changed to Aja and no problems since, on 2 different units.
I think BM have got their driver issues sorted now, but I didn't want to risk it happening again.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 04-26-2022, 03:02 AM
Farhoof's Avatar
Farhoof Farhoof is offline
There was a period (I think it started with the BM 10.5 driver) where video would always run out of sync. BM blamed Avid and Avid blamed BM afaik. This lasted over a year, maybe even two, I can't remember. Our Decklinks are running fine now, but I did loose trust.
Old 04-28-2022, 03:35 PM
npapaleo npapaleo is offline
I agree with the others re: Aja. I've used BM in the past and I always found the dance of figuring our the which driver/OS/PT version will all play well together to be a real hassle. Aja just works. Currently using the io 4k and I can attest it's flawless.
Old 04-29-2022, 09:50 PM
fork-media fork-media is offline
good support from AJA
I'm still not convinced about the AVE tho - using non lethal applications's. "Video Sync Pro" has me working steadily
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 04-29-2022, 10:02 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I switched from a Decklink to Aja (both PCI-e) and most problems gone away. Sync is more stable across different codecs as well.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 05-09-2022, 12:51 PM
First of all, apologies if this is hijacking the thread. Let me know and I can start a new thread.
Is it possible to put a Kona PCIe card (probably Kona 4) in a Sonnet PCIe TB2 chassis, alongside an HDX card? I'm thinking about picking up a used Kona 4 and using with a Gen10 and SyncHD for genlocked picture playback.
My system is currently a MTRX Studio connected to HDX1 in an older Sonnet Echo III-D TB2 chassis connected to a 2019 MacBook Pro i9 with an Apple TB2->TB3 adapter. PT Ultimate 2022.4/macOS 10.14.6.
Scott Gatteño
Old 05-09-2022, 01:55 PM
Pete Gates Pete Gates is offline
I don't think you'll even get a Kona 4 running like that on its own, let alone with an HDX card. You'll need a TB3 expansion chassis to handle that card and it'll probably saturate even that, so you still won't reliably run an HDX card with it.
Cheers,
Pete
HTML code is On
PT2020.5 and AVID Mojo DX video peripheral Ray JB Post - Surround - Video 6 09-03-2020 01:58 PM
Video Peripheral compatibility Syrcular Pro Tools 11 2 06-24-2013 11:39 PM
PT11 and Canopus Video Peripheral PT AJG Pro Tools 11 10 05-24-2013 12:19 PM
Media not supported by video peripheral error message meursiicc Pro Tools M-Powered (Win) 3 09-07-2009 06:41 PM
MediastationPT Satellite works w/o an Avid Video Peripheral? Dolly Post - Surround - Video 0 12-07-2007 01:25 AM
