Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
  #21
Old 08-24-2021, 03:45 AM
calmly44 calmly44 is offline
Default Re: Mix heavily Resonates sounds only in my car - JBL
Originally Posted by albee1952 View Post
You guys crack me up. EGS gave good advice, but let me expound on it a bit.
1-What makes a "pro" monitor? This is tough to quantify, but maybe the better answer is what DOESN'T make a "pro" monitor: Marketing hype and the average GC salesperson does NOT make a "pro" monitor(or headphone). A better source of advice(besides the pros here) is to get reviews(and not just 1 or 2) on what you are considering. 2 sources I like are SOS magazine and sweetwater.com. I'm not singling out GC, it could be any music store you can name.
2-Even the absolute finest monitors on the planet can(and will) sound like crap in a bad room(as I learned from experience). Speaker "correction" solutions can help, but will not work miracles, so if the room sucks, the software can make it suck less, but will never make it great.
3-try to do a least SOME treatment of the room. eBay sellers have rigid rockwool panels(2' x 4'). Get the 2" thick panels, wrap in burlap type fabric(frames out of 1" x 3" lumber give you something to staple the fabric to). Stack 2 diagonally across the corners and hang 1 on each side where a mirror would allow you to see your speakers(a reflection point). If budget allows, hang more on the wall behind you, and depending on the width of the room, hang a panel behind each speaker(especially for rear-ported speakers)
Here are some suggestions for better stuff(based on my experience, only):
Headphones(no order of pref):
AT Mx50
Sennheiser HD280 or 380
Shure 840(or better)
Speakers(no order of pref):
JBL LSR306 Mk II(best budget monitors IMHO)
Adam A7x
Presonus Eris 7
Adding a speaker switcher so you can AB between your Mackies and some "better" speakers can't hurt. As for testing in the car; absolutely a great idea, but do also listen to a couple of commercial releases to make sure those sound good too
Thank you so much
Sent from my Infinix X610B using Tapatalk
  #22
Old 08-24-2021, 03:46 AM
Here's a little experiment that might be an eye opener(ear opener?):
Sit in your normal mix spot and open a blank session. Put up a mono aux track and bring the fader down. Insert the signal generator plugin, set to SINE and put the frequency at around 225Hz. Bring the fader up to a comfortable volume and have a pencil and paper handy. lower the frequency in small amounts and listen at each new number for a moment. At some point, certain frequencies will disappear and others will get waaaaay louder. Those dipped areas are where you likely added low EQ to boost(causing the "ugly" sound in the car). The hotter areas are where you might have done EQ cuts(which you probably didn't need to do).
True. Thanks
  #23
Originally Posted by Bob Olhsson View Post
This is why it's not a good idea to get carried away with signal processing.
Thank you
  #24
Old 08-25-2021, 07:18 AM
EddieJones's Avatar
If you use your car as a listening test you should learn its peaks and dips. Most cars have a massive hump somewhere in the low end. Get a frequency generating App on you phone and do a sweep in the car. Mine has a 12+ db hump around 50Hz !
  #25
Old 02-09-2023, 07:35 PM
Jakew45 Jakew45 is offline
Hii buddy, I'm on JBL monitors too.
Something surely with reflections in your studio. Have you covered all the walls and bass traps carefully? Some sound in bouncing for sure. I used this: https://flyawayrecordingandmediastud...oustic-panels/
Headphone output heavily distorting on C400 Maris FireWire & USB Audio Interfaces (Win) 5 05-03-2022 06:29 AM
MBox2 Pro heavily distorted. WRETAUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 12-06-2010 01:57 PM
002r Monitor Outputs heavily distorted iamspartacus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-14-2009 02:14 PM
How to heavily color a vocal? highway51 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-05-2009 10:07 AM
Trying to record heavily distorted guitars pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-25-2004 06:14 AM
