How to use multiple instances of Play properly?
I'm trying to share two instances of Play between 12 or so samples. The first 6 I routed through channels 1-6 of Play on an aux track. Then I added another instance of Play under the first insert (same aux track) and added them on instruments 1-6, and then couldn't hear the first six instruments. So I figured I had to put the second set of instruments on channels 7-12 of the second Play. Still, the first six instruments are no longer working. It's obvious to me that I have no idea what I'm doing, and I'd really appreciate some guidance. |
Re: How to use multiple instances of Play properly?
I should mention that when I solo one of the first six instruments, I can see the piano keys moving along in Play - just no sound.
Multiple Instances of PT9 on same machine possible? | Matt_G | macOS | 5 | 06-16-2011 08:17 AM |
Multiple AudioDevMon.exe instances | MikeNH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-18-2011 11:01 AM |
multiple instances of RTAS | xartrax | Virtual Instruments | 6 | 03-15-2009 12:37 PM |
Using Multiple instances of Redrum in reason | eldusto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-25-2006 12:36 AM |
automation to multiple instances | tomcat | Tips & Tricks | 0 | 01-09-2000 05:58 PM |
