Old 06-14-2008, 10:53 AM
tonicjeff tonicjeff is offline
Default Expansion Chassis Question
is it possible to use cards in the chassis and also not in the chassis? The issue is this. I currently have PCI-x core, accel and one process card.. I want to get a new Mac Pro so I would get the chassis with the PCIx slots and the PCIe host adapter.. but can I also use a PCIe accel card in the computer at the same time as using the cards in the chassis? or will I be stuck with only using the cards in the chassis?
thanks
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram
4 internal sata drives (1 terabyte)
Magma Pci to PCIe 6 slot chassis
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 06-15-2008, 02:32 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Expansion Chassis Question
thanks
All cards have to be in the chassis!
get a PCIx accel card or get as many HD process cards as you can fit in the chassis
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-15-2008, 09:55 PM
Is there a major performance difference between using the PCIx accel in the chassis and the PCIe Accel directly in the computer?
Trying to figure out which will be a better choice when upgrading from my G5 to the mac pro..
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Expansion Chassis question? teacherman Pro Tools TDM Systems (Mac) 7 08-16-2010 07:02 PM
Question about expansion chassis Lizardpoint Pro Tools TDM Systems (Win) 0 12-07-2006 05:17 AM
Expansion chassis question? arche3 Pro Tools TDM Systems (Mac) 6 10-31-2006 01:02 PM
Expansion Chassis Question ProTooler Pro Tools TDM Systems (Mac) 2 02-07-2003 04:30 PM
Expansion Chassis Question - Please HELP!! ProTooler Digidesign Hardware & Software 0 10-31-2002 07:12 AM
