Old 08-01-2000, 08:55 AM
tld tld is offline
Default A general question on audio drive formatting
I started out using my Mix+ system on Protools version 5.0 and Mac OS 9.0 with an ATTO EPCI-DC dual channel SCSI card. I got myself a pair of 9GB Seagate Barracudas and simply initialized them with the Apple Drive Utility and everything worked fine. I even tested recording 64 tracks simultaneously...no problem. As a result, I've wound up paying little attention to the sometimes confusing threads here regarding FWB etc, and have never low level formatted either drive. In fact, the Seagate manual indicates that there should be no need to low level format them.
Two questions:
1. Is there any compelling reason for me to use anything else, or are most of these formatting issues mostly with the pre-5.0 software?
2. When I upgrade to 5.0.1 is there any reason I will have any problem with the drives as they are? (I'm still a little confused about the new formatting utility)
So far it ain't broke...so I ain't fixed it.....TIA.
Tom
[This message has been edited by tld (edited August 01, 2000).]
http://www.digitalaudiorock.com
The Protools Plugin Preset Co-op
Old 08-03-2000, 07:06 AM
tld tld is offline
Default Re: A general question on audio drive formatting
bump...any advice Digi?
Old 08-04-2000, 09:26 AM
jimlongo's Avatar
jimlongo jimlongo is offline
You shouldn't ever need to low level format a drive. Just quick format with FWB and IMO HFS+ is also a better way to go.
I would imagine that although digi recommends FWB, Apple drive setup will also work fine.
It is a good idea to reformat drives periodically. Backup / reformat / restore
jim
noise | jimlongo
Old 08-04-2000, 11:08 AM
tld tld is offline
Thanks much Jim. When you refer to quick formatting, I assume you simply mean simply initiallizing the drive. I plan to do the Backup/reformat/restore soon in case the drive may be getting fragmented.
Thanks again,
Tom
formatting an audio drive joshuah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-27-2005 06:48 PM
A "good" question on drive formatting basschair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2004 06:43 AM
HELP... Audio Drive formatting problem Bug0711 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-13-2003 08:40 PM
Drive formatting question:Extended or not? l anthony johnson Pro Tools TDM Systems (Mac) 7 06-05-2003 11:34 AM
Need help formatting dedicated audio drive MadeByNick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-06-2003 12:15 AM
