PT HD8 HD3 Magma can't find 192 connection
Hi I have a PT 8 HD3 system running on Mac Pro with osx snow leopard. I have 1x core and 2x accel pcix in a magma chassis.
The system has run flawlessly until today I'm getting the message "unable to find interface attached to first HD card". I have reseated all card in magma and in the Mac. I have reset smc and PRAM. Digitest passes but can't start protools and keep getting error. I even tried a different boot version of osx with protools on that and that was the same so I feel its hardware issue. Has anyone come across this before, If I cannot repair this I may need to upgrade but I do not want to go to HDX Im happy with HD |
Re: PT HD8 HD3 Magma can't find 192 connection
"unable to find interface attached to first HD card" sounds like the interface is bad or the cable to that interface has went south. I’d check those as this doesn’t sound like it’s your HD cards. If you have more than one interface/cable it should be easy to do.
First disconnect all interfaces/cable and start with just one interface plugged into your core card, if it doesn’t work swap cables. If it still doesn’t work swap interfaces. After that and it still doesn’t work I’d try a reinstall of Pro Tools. Good Luck!
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
Magma PE64r to Magma Expresbox 3T to Mac pro 2013 with Mavericks? | koka | Pro Tools TDM Systems (Mac) | 1 | 02-09-2023 12:04 AM |
Magma 3T HDX lost connection problem | JimmyM | Pro Tools HDX & HD Native Systems (Mac) | 1 | 05-06-2014 10:55 PM |
Where can I find a list of qualified Magma Chasis for PCIx to PCIe? | a2zproductions | Pro Tools TDM Systems (Mac) | 21 | 01-14-2011 02:09 PM |
Pro tools 9 can´t find a connection to 003 | bfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-28-2010 09:15 AM |
New Magma PER64/New MacPro / Can not find 192 ,Help! | magnottiprod | Pro Tools TDM Systems (Mac) | 4 | 12-29-2007 12:52 PM |
