Old 11-02-2022, 10:48 AM
digidesign78 digidesign78 is offline
Default NEW BUG (Double shortcup with numeric pad)
Hi, I have an issue with Protools Studio 2022 (Magic keyboard 2017 wireless / MAC STUDIO 2022). Since I installed it, I cannot use some Shortcuts : Apple+2 (session setup) / Apple+5 (Memory locations) etc...
When I use one of these shortcuts, it runs twice, so my window is never open. I know it runs twice because I see the "Window" or "Setup" menu flashes 2 times very fast.
I only have an issue with these shortcuts, all numeric pad shortcuts (Video, memory locations, automation, session setup etc...)
Thx for your awnsers
With regards
MX
Old 11-02-2022, 11:57 AM
Ben Jenssen's Avatar
Default Re: NEW BUG (Double shortcup with numeric pad)
Are you shure the window isn't showing on a different monitor, or a different 'Space'? Just a thought. I have this happen quite often with multiple monitors/spaces.
Old 12-29-2022, 11:08 AM
I wasn't at home since I posted this message. No, the problem is not this one. When I use a numeric shortcut, it applies 2 times. For example, apple+9 for video make appear and disapear instantly the Video Window.
I cannot use 1 and 2 for the transport but I can use 3 to record.
I tried with an other APPLE keyboard (with wire this time) and I have the same problem.
I have no shortcut in my OS
If someone has idea ?
MAX
Old 01-10-2023, 02:28 PM
enric.smart enric.smart is offline
I have exactly the same issue
I don't understand at all what's wrong, I'm just fed up with these bugs !
Pro tools 2022.12 on mac pro 6.1 / OS Monterey 12.6.2
Old 01-10-2023, 03:11 PM
mattrixx mattrixx is offline
I am not seeing that behaviour on my system.
Ventura (Mac Studio Ultra).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 03-15-2023, 01:53 AM
I just did the VENTURA 13.2.1 update and I still have the same issue with my protools's numeric pad shortcuts.
If I clic on "Window" to open the window menu (on the top bar), and next for example, apple+5 (memory loc), The Memory location window appear and the menu disappear. But If I dont open the menu beofre doing the shortcut, nothing is opening and I see the "Window" menu flash 2 times.
And when I already have the Memory location window open and I do apple+5, It closes the window (but still with 2 flash on the "Window" menu)
Anyone has an idea ?
Old 03-29-2023, 08:00 AM
Still the same issue with protools 2023 BUT I binded the shortcuts on other keys with the new customize keyboard system.
Old 03-29-2023, 02:01 PM
RobertDorn RobertDorn is offline
With regards
MX
Tried over here, Magic Keyboard on MacBook Pro m2 max under MacOS Ventura 13.2.1 , Pro Tools 2023.3 , works like a charm, no problem.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 03-29-2023, 02:04 PM
Are you on an intel Mac? The other user reporting this problem is on a Mac Pro 6.1 , perhaps it's an intel Mac related issue? I don't know ...
Old 04-02-2023, 01:26 PM
No I have a MAC STUDIO M1 // Magic keyboard // PT 2023.03 // Last mac os version
Numeric keypad. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-14-2011 03:51 PM
Numeric keypad Pais_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-04-2010 11:59 AM
Numeric Keypad MFR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-24-2009 03:58 PM
S-MUX / Double Speed / Double wire jiggy_bau Pro Tools TDM Systems (Mac) 3 06-27-2005 09:36 AM
numeric dB metering? Aaron Ross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-24-2003 04:45 PM
