Plugin User Defaults not loading
Hi all.
I'm running PT 2020.6 on Mac 11.6.8 and I've noticed none of my plugins are loading the User defaults I have previously set. I have tried redoing them but they just won't load by default. Same for all plugins. Is this a pref or a weird setting? |
Re: Plugin User Defaults not loading
Hi, Not totally sure - are your presets saved in User-Documents-Pro Tools-Plugin Settings-Plugin?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Hi Chris. Yes they are
Update. I've discovered some plugins do load but not others. They're all in the right folder but PT won't load the User default on some. Lost....
Are they Waves plug-ins? Waves 14.0 has a "set as my default" and when I did that, it comes up as the right setting, but where it would show the User Setting in the top right, it says <factory default>.
Any Waves plug-in that already had a User Preset showing top right prior to updating to 14.0 still show correctly and load correctly. Only user presets done after updating to 14.0 don't.
Thanks! That's Waves sorted. Any idea how to get the SSL Native Channel Strip 2 to work?
The waves central thing with a manufacturers plugin-manager storing stuff you don't know about, is more and more common. Acustica Audio is a grim example of this. I use DaisyDisk to quickly reveal unwanted stuff taking up disk space. Edit: This last paragraph I actually meant to post in a different thread! I don't know how I got it here.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. Last edited by Ben Jenssen; 07-27-2022 at 11:12 AM. |
Turns out SSL have disabled this feature because of the plugin mixer software. The workaround is to overwrite the default with your own using the Default Preset display at the very bottom of the plugin. If you click on it you can then 'save as default' with your own settings. Boom....
Thanks.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Now on to re-defining my default plugin settings on about 450 Waves plugins installed on my Mac, yay |
Plug In User Defaults Saving Automation Selections | Goombot | Pro Tools 12 | 0 | 03-23-2016 02:13 PM |
ProTools 10 to 11 and plugin settings/defaults | WildHoney | Pro Tools HDX & HD Native Systems (Mac) | 5 | 01-14-2016 09:46 AM |
Kontakt 5 not loading user pre sets | keith l | Pro Tools 9 | 0 | 03-10-2014 07:50 PM |
How can I export my plugin mappings and defaults? | usastra | Pro Tools TDM Systems (Mac) | 2 | 12-26-2010 12:47 PM |
How to set Mp3 plugin defaults? | jccrtv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-20-2006 09:00 PM |
