#21
Re: Pro Tools | Control vs. Neyrinck V-control pro
I figured it out. The only thing that bothers me, but I guess I understand it, is you can't use this along with my ProControl. Its either or.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#22
That's an easy choice then
#23
I am not quite sure I follow. Are you saying that you want the Avid Control app to also control other DAW programs? It can do that. EUCON will also mimic HUI control - just follow the instructions listed here: http://connect.euphonix.com/document..._Setup_3.0.pdf EUCON is an incredibly flexible thing. Far more than previous protocols created by Avid. As an example - I just opened an Ableton Live session followed by a protools session on the same computer. This means they aren't rewired together, I have two different sessions open. My artist series controllers and the iPad Control application will focus on whatever application I am working it. Switching between applications will switch the control surfaces and control because mackie control or eucon - and ableton live and protools. If you want to lock the control surfaces to a specific DAW, just bring the DAW to the front, open the eucon control panel and click the 'assign' tab - then activate the 'entire surface' checkbox below 'lock to application'. That will lock all the surfaces to the DAW you are currently working in. I haven't tried it with just the Control app, but it certainly is working with my Mix + Transport + Control app. Hui isn't entirely ideal - Eucon is definitely better, but it does work.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#24
Your review is spot on. Infancy is a good description. I can't believe there is no way to access send levels. If I'm working with the app as a remote, the ability to tweak a cue mix is just a basic requirement. Managing playhead locations in the timeline for punch or loop tasks is also not featured. Also Neyrinck has the ability to turn pre and post roll on and off easily whereas the Avid app doesn't even give the option. Logic Remote also eclipses this app in every way imaginable. It feels like this was rushed out the door just so Avid would have something to release and turn the tides of very negative user sentiment in light of the lack of progress on PT12 and the very unpopular HD support plan terms. Unfortunately shoving an incomplete product out the door only highlights Avid's deficiencies.
#25
The Control app can toggle pre and post roll. The soft keys can be programmed to control pretty much anything you like using the 'soft keys' panel in the Eucon software.
#26
So did you set up an ad hoc network here? |
#27
Yep,
I'm on a mac, so I hit "Create New Network" in the WiFi dropdown and connected the ipad to that network. Al |
#28
Cool, I'll try the ad hoc on PC. Gotta be the best way I reckon. |
#29
Also - cannot use EUCON and ICON together - its a pity!
Wanted to use it as a control pad in my recording booth - but cannot activate EUCON and my D-Command at the same time.
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks |
#30
Anyone tried the Actions app in PT?
Neyrinck V-Control Pro issues | Southsidemusic | Pro Tools 10 | 2 | 10-01-2013 12:20 PM |
Neyrinck V Control causes PT11 to crash | txshonk | Pro Tools 11 | 9 | 09-15-2013 08:25 PM |
Should Neyrinck Pro Control work | Southsidemusic | Pro Tools 11 | 3 | 06-21-2013 07:29 PM |
Neyrinck V-Control advice | Jon_Atkinson | Pro Tools 10 | 3 | 08-28-2012 03:42 AM |
NEYRINCK V-Control Pro NEW VERSION 1.6 Aug 13th 2012 | justus1900 | General Discussion | 0 | 08-14-2012 06:51 AM |
