Old 01-27-2004, 01:45 PM
doylemusic doylemusic is offline
Default Unable to hear playback of some files on my pc
Ok, this isn't really a true Pro Tools question, but I figured somebody might be able to help.
On the Pc that I use Pro Tools, I am unable to hear audio playback in some instances. I can play a cd in either of the 2 drives and I hear the audio fine. I cannot hear the audio when I play a file in CD architect, or an internet radio station, or Band in a Box (using the internal sound card), etc...
What is the deal? I have checked to make sure all Volume Controls are not muted and turned up.I am using the onboard soundcard on an ASUS A7v333 board.
It sure sounds like something simple, but I guess I am missing it. Any help is appreciated, thanks!
PT Ultimate 2020.3.0
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
Gigabyte GeForce GTX 1050 Ti 4GB
www.doylemusic.com
Old 01-27-2004, 03:40 PM
KingFish KingFish is offline
Default Re: Unable to hear playback of some files on my pc
well, first off, i'm assuming that you are monitoring the on-board soundcard mini jack output, through a mixer, or another set of speakers.
for 3rd part applications, you need to find the "audio" dialog... for example.. in CD architect, under...Options - Preferences - Preview tab, you'll have a pull down menu - Microsoft sound Mapper - windows classic wave driver - (and your sound card will be called something like C-Media) you may want to go into your device manager to find the name of the on board sound card.... you need this card selected, for audio to play out it.
again, it will plau out the green mini jack, built into the mother board, on the back of your computer.
If you d/l Rail's MME Helper (do a DUC search) you can register most of these apps with the wav driver 6.1.1 and play the audio right out your pro-tools monitoring.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 01-28-2004, 11:57 AM
Thanks Kingfish, I'll take a look at your suggestion on using the Wave Driver.
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
www.doylemusic.com
Old 01-28-2004, 02:09 PM
Kirby B. Kirby B. is offline
Some pc audio players won't play 24 bit files. Could be the case here. My Windows Media Player 9 won't, or I just don't know how to configure it. Winamp will, however.
Good luck
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Unable To Hear what I recorded In PT9 Mike1005 Windows 7 01-09-2013 07:40 AM
Mbox2 Pro - unable to hear inputs without having PT on cosmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-25-2012 06:05 AM
How can I hear when playback Rockman413 Pro Tools 10 1 04-18-2012 01:35 AM
Unable to import REX or Acid files as group files in 7.4 Luigi Lazareno Pro Tools TDM Systems (Mac) 2 03-11-2009 08:07 PM
Unable to hear midi in playback cstancil MIDI 1 01-02-2008 01:42 PM
