Old 01-07-2001, 10:34 AM
Dawson79 Dawson79 is offline
Default Cannot Hear Midi Playback
When I record a MIDI track it records and I can only hear the sounds when in record mode. Then When I go to play it back I cannot hear anything. I shows the MIDI's Level going up and down with the notes but the Aux input Stereo Fader's level doesn't move. What I have is an Roland XP-30 and I connect it this way, MIDI in connected to OO1 and the 001's out to my XP-30's in. the Aux (stereo) fader in's are 3&4 and the out is Analog 1- S/PDIF L Analog 2. Everythings levels and volumes are turned up also. The weird thing is that it was working the other day now It doesn't go figure
Thanks in advance,
Dawson79
Old 01-07-2001, 07:18 PM
mfym mfym is offline
Default Re: Cannot Hear Midi Playback
From what you've described, it sounds like your set-up should work. If it was working, I'm sure you'll be able to trouble shoot it.
The only thing you didn't mention is whether you have a master fader set up. Another simple fix is making sure the volume is up on the keyboard (it happens).
Old 01-07-2001, 09:28 PM
RolandK RolandK is offline
This is no help, but I have the exact same problem and it's driving me crazy! I'm using a Yamaha DS10 electronic drum kit with the same connections as you. When you record everything is fine, output volume on the drums is up, faders on 001 mixer are up, lots of happy signal on the aux track and midi track, and the midi dots are being plotted. When you play it back, the aux channel is dead and you don't hear anything.
I have a midi keyboard and electric drum kit...I can only hear drum's midi playback thrice506 MIDI 0 02-09-2014 11:18 AM
I can't hear MIDI Playback. YichenWang Getting Started 1 12-30-2013 02:47 AM
Can't hear anything from midi playback...... the viking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-16-2007 05:56 AM
Can't hear midi playback msmusic MIDI 3 02-20-2006 06:54 PM
Can't hear MIDI playback Qwack MIDI 1 01-12-2004 11:24 AM
