Old 03-10-2004, 08:30 AM
jorg jorg is offline
Default playback stops all the time
Hi, I'm running PT LE 5.3.2 on Win XP (AMD XP 2300+) with a digi 002. Sometimes I can work perfectly fine for hours but most times when starting to play a song the window: "The operation system held interrupts for too long. If this occurs often, try to increase the "H/W Buffer Size" in the Playback Engine Panel (-6089)" appears all the time.
Well, my buffer is on max already and applied all windows setting which are recommended by digidesign. Are there any additional settings I have to make???
Cheers
Jorg
Mac Pro Nehalem 8 core 8 GB Ram
OS: 10.6.8
Pro Tools 10.0.1
RME Multiface II with Focusrite Octopre mkII
Old 03-10-2004, 08:37 AM
Bazzle Bazzle is offline
Default Re: playback stops all the time
Do you have a lot of plugins inserted?
Bazzle
Old 03-10-2004, 08:40 AM
that's the funny thing. sometimes it works perfect with tons of plugins but it happened again just now with no plugins at all.
Cheers Jorg
OS: 10.6.8
Pro Tools 10.0.1
Old 03-10-2004, 08:49 AM
I sometimes find this happens when I try to do things to quickly..Like push the buttons on my Hui to fast, other than that it only happens when I'm overloaded with plugins and automation..That's all the info I have on this problem
Bazzle
Old 03-10-2004, 08:53 AM
Maybe I should install Win XP with service pack 1.
thanks a lot anyway.
Cheers
Jorg
OS: 10.6.8
Pro Tools 10.0.1
Old 03-10-2004, 09:02 AM
You must have SP1 for it to function properly..You can download it from Microsoft update page
Bazzle
Old 03-10-2004, 09:06 AM
Alright, i'm gonna do that now, hopefully it helps.
Cheers
Jorg
OS: 10.6.8
Pro Tools 10.0.1
Old 03-10-2004, 09:14 AM
It will make a world of difference..
Bazzle
Old 03-10-2004, 09:22 AM
And by the way..Welcome to the DUC..I see your from the birthplace of "Four Lads Who Shook The World"...May you have a similiar success
Bazzle
Old 03-10-2004, 10:06 AM
Thanks for the welcome.
Actually I'm german. I'm just studying in Liverpool.
OS: 10.6.8
Pro Tools 10.0.1
Hint!: Set a long post-roll time to avoid annoying playback stops! EricWillhelm Tips & Tricks 4 07-01-2013 05:11 PM
PTLE8 Playback stops at end of time selection? Blank Frank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-25-2009 08:55 PM
Pro Tools always stops playback ( for a short time Flohre Pro Tools M-Powered (Win) 2 02-13-2007 05:18 AM
6.7 stops playback after 20 sec... Kling3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-25-2005 07:31 AM
How do you keep selection after playback stops? who Pro Tools TDM Systems (Mac) 5 04-07-2001 04:14 PM
