Hey All,
I am all of a sudden only getting a minimum value of 49 on my cc11 Expression pedal. I have tried resetting the Axiom using the "press + and - while powering up" and it won't reset. I have also tried uploading the Axiom49 preset from Enigma to the keyboard and nothing will change the minimum cc11 value back to 00. I am literally in the middle of re-writing a few pieces of music for a project and I need my expression pedal up and running. Help! I have tried everything I can think of and nothing seems to be working. Thanks for any advice, Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2021.7 / RME UFX+ Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 12.5 |
Hi Andrew,
Is it possible to assign a different CC number? Does this same problem happen if you assign a different CC to the pedal? Do you have another keyboard you can try the pedal with? I have a feeeling the problem is the pedal itself, and the same output will happen regardless of what You use with it.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Andrew,
I had and still have a similar problem. The Hammond Organ B33 VI - tried to tie the Wah pedal to it so I could control the speed of the leslie, but it all the way up, it doesn't go to zero, it bottoms out at about 75%. Here's my post, but unfortunately, it won't help me. I'm going to keep my eyes on your thread. http://duc.avid.com/showthread.php?t=331224 Fred |
Axiom 25 Problem Help!!!!!! | louislboy | MIDI | 0 | 08-15-2012 02:20 PM |
Axiom Pro 61 LCD screen problem | zedhed | MIDI | 1 | 03-19-2011 03:32 AM |
Problem with my axiom and pro tools m powered | meissner | Pro Tools M-Powered (Win) | 6 | 01-05-2011 02:05 PM |
PT MP and Axiom Pro 25 problem | clausiii | Pro Tools M-Powered (Mac) | 3 | 06-24-2010 03:51 AM |
axiom 25 as controller for PT 8 problem | harryk | MIDI | 11 | 03-20-2009 10:48 PM |
