Old 03-20-2012, 01:57 PM
earshatter earshatter is offline
Default Pls Help, Assertion Error....
Here is the error:
Neo Assertion in "/Volumes/Development/we.ProTools_8.0.X/AlturaPorts/SDKs/Neo61/Libraries/Macintosh/Environments/Alone/../../../../Source/CNeolnode.cpp", line881
I've never seen this one before. Running MacbookPro, 8gb ram, PT 8.0.5, mbox2, dvtoolkit2.
I've been running this system for 2 years. No problems. The other day I was importing sound files and all was still good. (I work in post as a sound editor). After 20-30 edits, I needed to create something. I did and tried to rename it. When I press return, I get the error. So, I can edit and I can do everything (so far) that I normally do, but when I go to rename, it slaps me.
*Addition*
I've realized that I'm not able to use the stretch tool also. This is major....Any help is good help.
I threw out my digidesign database on all my drives, reinstalled PT and everything involved with it. Still the same thing. I went through the session and removed any suspect files, and moved the corresponding to the trash. THEN, I opened a session that is completely separate from the others. Same thing.
Anyone have ideas? I thought it could be corrupt files or database. What gives!?
Thanks in advance.
Absence of evidence is not evidence of absence...the truth is out there.
Old 03-25-2012, 01:23 PM
JazzyJ JazzyJ is offline
Default Re: Pls Help, Assertion Error....
Create a new blank session and then import the tracks from the problematic session. See if that makes a difference.
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 03-26-2012, 12:48 PM
Craig F Craig F is offline
General NeoAccess or Assertion errors
If you receive one of these errors, usually after recording or when trying to save a session, it can usually be resolved by following the steps for trashing preference and database files listed above.
Thank you,
Craig
Assertion in....Error GMFx macOS 15 01-05-2018 11:48 AM
Can't complete request- assertion error and wmTDM Flag error crizdee Pro Tools TDM Systems (Mac) 3 06-25-2009 03:56 PM
Assertion Error 305 with BFD Logan M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-07-2007 01:35 AM
Assertion Error-HELP! Matthewnyms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-12-2007 07:19 PM
OMF Import error Assertion Error 4044 DUCHUNTER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-08-2005 12:45 AM
