Old 12-29-2010, 04:55 PM
hammerransom hammerransom is offline
Default Mbox 3 PRO - Headphone B = no sound
My B input for my headphone jack doesn't seem to be working.
Anybody else had any issues with this? Is there something I need to do other than plug headphones into the jack?
I plug into input A and that works great...
Old 12-29-2010, 05:21 PM
Default Re: Mbox 3 PRO - Headphone B = no sound
Never mind, I figured it out... If you run into this and you need both A and B to monitor the same overall signal, do this.
- Go to the start menu and open Control Panel on your PC.
- Pull up the Mbox Pro control panel icon.
- Highlight "Headphone B" and change the drop down to match whatever headphone A is. In my case A was set at stereo mix 5 and B was set at stereo mix 6, so A was playing audio but B wasn't.
Old 05-06-2011, 04:15 PM
Bazbone Bazbone is offline
I had the same problem but hadn't spotted that - thanks! Typing Mbox pro in the quick find on a mac (Spotlight) finds the control panel instantly...
Old 06-09-2011, 05:08 AM
risey's Avatar
risey risey is offline
I am having the same problems:
Somtimes the Audio comes out of Headphone A and not B
Audio somtimes only comes through left or right channel in the headphone even when the output meter shows 2 channels of audio coming out.
Audio sometimes has a loud distortion sound
Sometimes there is no Audio at all.
Please note no setting were changed, so its not me, when i restart the pc it seems to work again.
Risey
Old 08-13-2011, 10:25 AM
birdfluvirus birdfluvirus is offline
Dude, thanks sooo much. Saved me from buying a support ticket.
"If I could fly, I wouldn't"
Old 09-18-2012, 09:41 AM
Ferrante Ferrante is offline
Thanx. This fixed it for me. Headphone B was linked to Stereo Mix 6.
Old 06-09-2013, 05:07 AM
MrPin MrPin is offline
Almost got me nuts! Thanks a lot homie
Old 07-29-2013, 10:41 AM
Brad Newman Brad Newman is offline
This should function on Stereo Mix 6 as that is the default. Setting it to Stereo Mix 5 will work for most setups, but is a band-aid as you can provided different mixes to each headphone output. I had the same issue. Turning off the mbox pro AND the pc, restarting everything while changing no settings resolved my issue. This has happened twice in 3 months. I believe it is some kind of initializing, software bug or driver issue as just turning off the mbox pro did alone did not fix it. It required a PC shutdown and restart.
Old 01-11-2014, 07:10 AM
fabco fabco is offline
http://www.sweetwater.com/sweetcare/...eadphone-a-is/
This might help
Mbox Mini Headphone Jack No Sound TheABN34 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-30-2013 07:38 AM
MBox Pro 3 Headphone Problem (No Sound) DJKeys macOS 3 08-28-2013 06:59 AM
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
Mbox 3 Pro No Sound from Either Headphone Jack unctuous Windows 1 09-16-2011 07:34 PM
No monitor/headphone sound from Mbox 2 Pro Welby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2006 10:54 PM
