Everytime it select a plugin with the mouse with a MIDI controller enabled in the peripherals (in my case Axiom Pro 25 via Hypercontrol) the mixer in the mixer window and the tracks in the edit window move by itself to another position. I assume PT will show me the bank which is active in the controller. But that´s not what i want. Sometimes i want to edit or mix on other tracks than on the active bank and sometimes my track moves out of the windows.
How can i fix this? Thanks
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
If that track (plug-in) is in another bank the Axiom Pro will jump to that bank.
Aaron Mulqueen - 001 HD Native |
you can turn off edit window follows track selection (i think thats what the option is called) it wont really help the banks moving in the mix window but if you editing you wont loose your spot.
Thanks, i´ll give it a try!
Axiom 49 CC Value Problem | blizzard | MIDI | 2 | 05-14-2013 08:34 AM |
Axiom 25 Problem Help!!!!!! | louislboy | MIDI | 0 | 08-15-2012 02:20 PM |
Axiom Pro 61 LCD screen problem | zedhed | MIDI | 1 | 03-19-2011 03:32 AM |
Problem with my axiom and pro tools m powered | meissner | Pro Tools M-Powered (Win) | 6 | 01-05-2011 02:05 PM |
axiom 25 as controller for PT 8 problem | harryk | MIDI | 11 | 03-20-2009 10:48 PM |
