Old 01-13-2009, 01:33 PM
harryk harryk is offline
Default axiom 25 as controller for PT 8 problem
I previously was able to use my axiom 25 as a controller for pt7.4. Now with pt8 it's not working. I downloaded the legacy cooper (CS-10) dll and put in the c:\Program Files\Common Files\Digidesign\DAE\Controllers directory. I also used Enigma to load the xml file to the axiom 25.
When I open the peripherals in pt and attempt to add the CS-10 under MIDI Controller type the Receive From, Send To, and # Ch's do not become active. If I select ok without changing the MIDI Controller type I get the following error:
Could not complete the peripherals command because Access Violation occurred, unable to read location: 0x00000014 at address: 0x04205B2 in module: ProTools.dll
Also, after trying to add the CS-10 I cannot close the Peripherals window.
I have the axiom 25 connected using usb and not midi cable to an MBOX 2.
Any thoughts?
PT 12, Gigabyte GA-X79-UD3 ATX LGA2011 MB,Intel Core i7-3930 3.2GHz 6-Core Processor,Asus NVIDIA GeForce GT 640 2GB GDDR3 PCI-e Video Card, Patriot Viper 3 Low Profile Blue 32GB (4x8GB),Cooler Master Hyper 212 Evo CPU Cooler, Rosewill Stallion Series RD700 700W Power Supply,Western Digital Caviar Black Internal system/session/samples,Windows 7 Professional 64-bit,Mbox2
Old 01-13-2009, 04:50 PM
gdugan gdugan is offline
Default Re: axiom 25 as controller for PT 8 problem
Look around at some recent threads under 'Virtual Instruments.' There is some info about using an Axiom to control Pro Tools.
Old 01-13-2009, 07:56 PM
thanks, I did do a search and found items that were dated before digi put out the updates to Legacy MIDI Controllers - Pro Tools 8 dated 1/06/09.
The cs-10 isn't working for me.
cheers, harryk
Old 01-22-2009, 10:11 AM
Jed27 Jed27 is offline
So is the CS-10 control surface personality file works as before on Protools 8?
I can see it in peripherals but can't choose the same as Harryk...
Thanks.
Old 02-05-2009, 10:06 AM
simonsmusic simonsmusic is offline
this is how to get your axiom to work with proTools 8........
first of all forget about enigma...its crap...
In protools set up your axiom 25...choose generic midi controller.
then go to setup/peripherals.....under the Machine Control tab check "Enable machine control Remote slave" then under the Midi controller tab choose M-audio Keyboard and choose the port its connected to on both. and choose ok.
were going to program each button manually.
for each button we program your going to always do "Step One" for each Button we program ..
Step One
1)Press "Advanced" then "Ctrl Assign" on the keyboard "its the first white key" then push or turn the button you want to program.
lets get started......
Transport buttons:
First perform step one ....
for the record button enter "cc 118" then enter. now do step one again but instead of pressing "Ctrl Assign" press "Data 2" its one of the black keys and press the numer one and hit enter.
your going to do the same thing for the rest of the transport buttons using these CC numbers
Play-CC 117
Stop-CC 116
forward- CC 115
Rewind-CC 114
Dont do anything with the loop button its just going to screw up the rest of the buttons..?dont know Why?
To get the knobs to control the faders do step one then use these CC #s
CC 33 to 40 controls the first 8 faders .
example:
fader one first Perform step one.
then use CC 33 after thats done
press "Advanced" then press data 2 and hit 0 and for data 3 enter 127 then hit enter........like magic, you should see your faders moving...
any questions just drop me an email at art2701@hotmail.com or visit me at www.mybeatshop.com/simonsmusic
Drop me a comment and let me know if I was helpful...
P.s I Sell beats on www.Mybeatshop.com/simonsmusic let me know what you think about them
Old 02-05-2009, 12:52 PM
lego lego is offline
IDK about Mac, but on PC this works absolutely no poblem:
If you use preset 20 (Axiom) or 10 (Oxygene) back it up using Enigma!
1. Make shure your Axiom driver is properly installed
2. In PT goto Setup -> Peripherals -> MIDI Controllers
3. Select: Type -> M-Audio keyboard
4. Select: Receive From -> Prefefined -> Axiom 1
5. Select: Send To -> Predefined -> Axiom
6. Click OK
7. Observe the display on your Axiom - it should display S Y S for a moment.
8. Now set your Axiom to Preset 20 (press Recall and use + and -)
9. You are all set!
This works similar for Oxygene, except for the Preset number, which is 10.
Now your Transport buttons control Transport in PT, if you have Sliders they control the faders, the buttons below the sliders select channel, while knobs are for pan (on the Axiom 25 the knobs control faders).
The Loop button switches focus between the Mixer and Plugin Windows.
Enjoy!
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 02-06-2009, 10:56 PM
Teolin Teolin is offline
Thanks, lego.
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
Old 02-07-2009, 04:36 PM
bobzuruncle bobzuruncle is offline
Hey Lego - just back from a gig having lost a day of work and a couple nights of sleep with my new Axiom 61 not talking to my 003 rack in PT8! Decided to register for this forum and found this thread.
Just like to say Thank You!!!!!
You have made a very confused musician very happy with your cool fix!
Why can't they make these things work out of the box?
Old 02-14-2009, 12:10 PM
LitBeatz LitBeatz is offline
does this method work with the mpk49?
Old 02-23-2009, 04:03 PM
britune britune is offline
lego- Thanks for the fix!!
After I upgraded to PT8, I lost my MIDI connection to my Axiom 61. Your suggestion fixed my problem for the song that was loaded at the time I did the fix.
But I still have the same problem when I load the other songs. I went through the same procedure and it doesn't fix the other songs.
Any ideas???
Help with Axiom Controller ...Please pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-27-2009 03:08 PM
Axiom Pro controller hki Virtual Instruments 0 01-16-2009 08:33 AM
Help- Axiom 61 Keyboard Controller Superbee Virtual Instruments 3 08-05-2008 09:28 AM
Help with Axiom 49 as PTLE controller jimmyzk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2008 03:14 PM
Axiom 49 as a controller for Pro Tools 7.3 illyaas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-02-2007 03:04 PM
