Closed Thread
Old 06-01-2007, 05:16 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools LE 7.3.1cs3 Update for Windows XP
Available for download from the Pro Tools 7.3 and core system downloads sections, and the Pro Tools CS Updates quick link in the Support section: http://www.digidesign.com/index.cfm?...4&itemid=23300
In addition to all previous 7.3.x fixes, the Pro Tools LE 7.3.1cs3 update for Pro Tools LE 7.3 & 7.3.1 adds the following:
Random Disappearance or Corruption of Regions On Tracks When Editing Or Punching In (Item #85976)
* Although this could occur while editing or recording over regions, the problem was most evident when QuickPunching over existing regions.
Attempting To Play From The Beginning Of A Session May Fail (Item #85674, 93283, 93289)
* After the play command, the Play and Stop buttons flash, but Pro Tools does not play
* Repeated attempts may result in a successful play
Importing Audio Files From A Sound Devices 744T Field Recorder Causes Multiple Problems (Item #90570, 90726)
* Audio files would not have a Unique ID assigned to them
* An assertion, "FF AudioProperty.cpp, line 33" would be thrown when overviews were being calulated
* Audio could be unreadable by Pro Tools
Enabling Low Latency Monitoring Could Cause Loss Of Output Signal With a Pro Tools LE FireWire Audio Interface: 003 Family, Digi 002 Family , Mbox 2 Pro (Item #89073)
* Note that although the output signal would stop, the meter would still indicate signal present
Administrator
Closed Thread
Pro Tools HD 7.3.1cs3 Update for Windows XP - Reposted Avid Pro Tools TDM Systems (Win) 0 06-20-2007 09:05 PM
Pro Tools M-Powered 7.3.1cs3 Update for Windows XP Avid Pro Tools M-Powered (Win) 0 06-01-2007 05:21 PM
Pro Tools LE 7.3.1cs3 Update for Mac OS X Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-01-2007 05:13 PM
Pro Tools HD 7.3.1cs3 Update for Windows XP Avid Pro Tools TDM Systems (Win) 0 06-01-2007 05:07 PM
Pro Tools HD 7.1cs3 Update Avid Pro Tools TDM Systems (Win) 0 01-20-2006 07:05 PM
