Old 06-14-2022, 04:01 AM
Batpro Batpro is offline
Default 25 seconds for save a session with virtual insert
Hello there,
I’ve a strange behavior on Pro tools ultimate on a Mac Studio 32Gb of Ram: a virtual instrument session with 4 East West Opus in multi channel mode. Symphonic Orchestra setup.
I had the “spinning wheel of death” for 25 seconds and after some anxiety I released that this happens during the save and auto-save procedure.
The system usage window shows that all is in the confort zone: memory 35%, CPU very low and the Disk (a very fast NVMe 2Gb/sec via thunderbolt) always at zero, even during the saving procedure.
I’ve tried to preload the samples in various way but nothing happens.
I’ve moved the session on the internal disk: the problem is exactly the same, 25 sec. for saving.
I’ve the same virtual instrument setup on a Sibelius score and the save is instantaneous.
With a session audio-only everything works flawlessly.
Mac M1 Max, 32gb RAM, Sandisk extreme pro, Monterey 12.4
Opus don’t needs Rosetta.
Thanks, cheers
Old 06-14-2022, 10:25 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: 25 seconds for save a session with virtual insert
Hi, Is it just that one session or does it happen in other sessions or a new session with only that plugin in use?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-18-2022, 04:53 AM
New empty sessions or with only audio tracks works fine.
New sessions with Opus have this issue.With one instance few seconds, with two 10 seconds and so on, with four: 25 seconds.
Old 06-18-2022, 10:15 AM
bradch00 bradch00 is offline
Hi there,
Even though Opus runs natively on Apple Silicon, it still requires Rosetta 2 (Intel) support to run as an AAX plug-in within Pro Tools.
Perhaps that code is creating some sort of bottle neck.
Maybe reach out to EW tech. support?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 06-18-2022, 10:46 AM
this make sense.
I can try to do the same situation in Logic, so all native, and see what's happens
Old 06-18-2022, 02:16 PM
Marsdy Marsdy is offline
Originally Posted by Batpro View Post
Hello there,
Thanks, cheers
It’s been a while since I’ve used EW VIs but one of the reasons I gave up was that saving and auto-saving in Pro Tools took so long. Obviously Pro Tools saves the status of any instantiated plug-in and VI whenever it auto saves. Maybe they’ve still not fixed this?
Once possible solution is to use EW in Vienna Ensemble Pro in “decoupled” mode.
Dave Marsden
UK
HTML code is On
Save session, close session, open session next day...clips have moved. ptr22 Pro Tools 12 8 02-18-2016 06:34 AM
Should I Save Virtual Instruments on mac or external hard drive? moya83 macOS 14 11-12-2015 05:08 AM
LOUD White noise every 15 seconds upon session load.. (before any playback or rec) awritersparadise Pro Tools 9 5 04-28-2011 06:51 PM
can i save insert settings and open in different projects JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-09-2009 10:55 AM
Feature Request: Save Insert Layer dsteinwedel Pro Tools TDM Systems (Mac) 3 01-19-2009 06:45 PM
