Old 06-08-2022, 06:06 AM
TP Audio TP Audio is offline
Default New to MIDI - note lengthen problem
Hi there
I started my first Instrument track with standard Mini Grand. I have my 88 key digital piano connected to play this. Once I lay some simple notes I notice that the note has a small vertical line in front. When I go to move it slightly in slip mode the little line stays and the note moves ether side of it so I end up getting another small piano hit.
Other tutorial videos I've seen don't seem to have this line. Any suggestions would be a great help.
Old 06-09-2022, 05:09 AM
Default Re: New to MIDI - note lengthen problem
I worked it out. I think.
The thin bar in front seems to be a marker indicating the original place the note was recorded.
When I move the note along the thin bar remains but I found I can remove the bar by double clicking.
I was looking all over the net to find this but nothing. Obviously not looking hard enough.
Old 06-09-2022, 12:21 PM
Marsdy Marsdy is offline
Attachment 15993
That looks like a double note event is being recorded. This usually happens as a result of a MIDI loop or perhaps a MIDI controller sending out the same note on two different zones.
Dave Marsden
UK
Old 06-10-2022, 03:30 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
What Marsdy said. You can also look in the MIDI event list to verify this without moving the notes.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Weird midi note length problem nyjdams macOS 6 01-08-2015 09:16 AM
Midi note problem Axiom 49 and Pro tools 8 wearetheniceguys.com MIDI 7 05-20-2012 03:20 AM
midi import one note problem dzjango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-06-2010 01:59 PM
How to lengthen a MIDI Region without TCE? Dizzi45Z Tips & Tricks 8 01-03-2009 08:42 PM
Strech or lengthen an audio note? rqstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-15-2007 11:01 AM
