Old 05-15-2022, 02:13 PM
rantanplan rantanplan is offline
Default Altiverb XL + Stereo/Quadro IRs - Good for LCR?
Hi there,
I wonder how others use Altiverb for sounds which are panned off center in LCR configuration.
For louder things that draw the viewer's attention, simply panning a mono reverb is not good enough IMHO especially in bigger spaces.
In most cases I use Phoenix Surround reverb on a LCR or 5.0 bus for this. But sometimes I'd like to use Altiverb because some of its IRs were a perfect match for the dialogues or in Speakerphone.
Unfortunately most of the IRs (if not all) are only stereo-stereo or stereo-quadraphonic. Now I wonder if it's OK to just turn up the center level control in Altiverb? Is this simply the sum of the left and right responses?
Thanks
Last edited by rantanplan; 05-16-2022 at 05:32 AM. Reason: Title add specific Version
Old 05-15-2022, 02:52 PM
Default Re: Altiverb + Stereo/Quadro IRs - Good for LCR?
RTFM!
Outputs a delayed sum of the rear channel into the center channel to fix possible gaps. In-tended for post production usage to prevent dry dialogue in the center channel, or gaps in the reverb image in wide theater setups. For all musical purposes the recommended setting is all the way down (no center bleed).
Interesting approach...
But not good for stereo mixdown.
Old 05-16-2022, 03:15 AM
reichman's Avatar
reichman reichman is offline
Are you using Altiverb XL? Depending on the IR, that might help.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 05-16-2022, 05:35 AM
Ah yes. It's the XL. I added it to the title. Thanks!
It's on a 5.0 bus hence I shows level adjustments for front, rear and center.
Old 05-16-2022, 11:31 AM
spoons's Avatar
spoons spoons is offline
Default Re: Altiverb XL + Stereo/Quadro IRs - Good for LCR?
I use Spanner after Altiverb to toe it into the centre when using it on dialogue.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 05-17-2022, 02:58 AM
Cheesehead Cheesehead is offline
I've always just turned up the center control.
It never seems to cause a problem.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 05-17-2022, 06:03 AM
Hard to believe but I don't have Spanner
What does it do, it calculates a real center, like M/S processing?
Old 05-17-2022, 06:06 AM
That's reassuring! You also did stereo downmixes?
Old 05-17-2022, 10:49 AM
dr sound's Avatar
dr sound dr sound is online now
https://www.thecargocult.nz/products/spanner
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 05-17-2022, 11:13 AM
Originally Posted by dr sound View Post
Thanks, I know the plugin. But I wonder what it really does when you "tie it to the center"...
HTML code is On
Quadro NVS 295 Video Card - x1 or x16 David Lang Windows 0 03-06-2012 02:17 AM
NVidia Quadro required? being_me Pro Tools 10 7 12-28-2011 12:59 PM
Altiverb 7-XL rtas in PT 9-TDM - OS 10.6.x - good or bad? MixerGuy Pro Tools TDM Systems (Mac) 6 12-12-2011 10:14 PM
GeForce vs Quadro vs ? dstryrwiz Pro Tools 9 4 02-08-2011 09:02 PM
good stereo pre for oh.... nate9 Pro Tools TDM Systems (Mac) 9 05-11-2009 12:54 PM
