Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-16-2020, 07:17 AM
JayRay JayRay is offline
Default Carbon and Mac Pro 5,1 compatibility
I still don't get it is this interface compatible with Mac Pro 5,1?
As we know, there is thunderbolt card now available for these Mac Pros via Gigabyte.
Or is it possible to connect to Mac Pro also with just ethernet cable?
I can't find the real answer.
Old 12-16-2020, 07:36 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Carbon and Mac Pro 5,1 compatibility
Well the real answer depends on exactly what (you) mean by "compatible" do you mean "compatible" as in listed
as "Supported" by Avid then No it must be 6.1 and up
here are the supported computers listed by Avid
https://avid.secure.force.com/pkb/articles/compatibility/Carbon-Requirements#computers
OR Do you mean compatible as in "can it possibly work unsupported" Answer is Maybe ?
First
You need to list your entire exact system details before you're going to get much of any kind of accurate answer
In general
Carbon is only qualified on Catalina 10.15.7 and PT 2020.11 and later
So depending what year your 5.1 you may need to upgrade to a metal capable Graphics card and again depending on specific 5.1 you may have to use an unsupported 3 rd party patch app to even run Catalina
If your 5'1 has a Gigibyte capable ethernet port it should (theoretically) work
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 12-16-2020, 08:03 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hi JayRay,
Carbon is not supported with Mac Pro 5,1 as it doesn't support AVB. Only Macs with Thunderbolt support AVB. I can't speak to whether the Thunderbolt PCIe card will support an AVB connection. Even if it does, and you can install 10.15.7, run a supported graphics card, etc, I wouldn't recommend it. We've done zero testing on Mac Pro 5,1 and that won't change in the future. You're better off waiting to purchase Carbon when you can use it with a qualified Mac. See list here.
Hope that helps.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 12-16-2020, 10:04 AM
K Roche's Avatar
Well there ya go I stand corrected , I forgot about AVB. thanks Kyle
System :
Enjoy the Journey
.... Kev...
Old 12-16-2020, 08:08 PM
LukeHoward LukeHoward is offline
Yeah, I wouldn't expect much luck with AVB on a MacPro5,1. I tried an Intel I210 card in mine (which works for networking and appears from the symbol table to support AVB), but avbutil reports it as unsupported when attempting to enable virtual-audio.
This is on Mojave, it might be different on Catalina, but that's unsupported on a MacPro5,1...
https://lukehoward.com/
Old 12-17-2020, 06:38 AM
K Roche's Avatar
Which is why (because my previous system was HDN Omni on a Mid 2010 Mac pro) and I was trying to decide on a new Computer and or Mac Pro or iMac with TB 3 HDN box The when Carbon was announced I decided to go for it and the new iMac listed in my sig line
System :
Enjoy the Journey
.... Kev...
Old 07-13-2021, 07:53 AM
martthie_08 martthie_08 is offline
sorry to hijack, has anyone had success with Carbon on older (mid 2013) Macbook Air with Catalina?
this would only be for location/live recording, mixing is done on a desktop with HDX..
Old 07-13-2021, 09:01 AM
dominicperry dominicperry is offline
Officially (Apple) - any Mac with a TB port supports AVB. But I strongly suspect that a 2013 MBA isn't going to cut it with both PT and the overhead of running an AVB interface, which seems to put quite a bit of pressure on the CPU, even without an audio passing.
The minimum MBPro Avid spec to support the Carbon is:
Late 2016 Retina 15" MacBookPro13,3 Quad-Core i7 'Skylake' 2.9 GHz
The minimum MBAir Avid spec is:
2020 MacBook Air 10,1 8-Core M1 'Silicon' 3.2 GHz / 7-Core GPU with 16GB Memory
https://avid.secure.force.com/pkb/ar...ements#adaptor
Old 07-13-2021, 09:05 AM
thanks for your reply!
yes I've seen the minimum specs..
this is just for using ProTools as a tape machine, no plugins whatsoever.
I was able to do this 15 years ago on a 400MHz Powerbook G4 recording 24 tracks :)
Old 07-13-2021, 09:12 AM
I've got a 2011 MBA that I can try - let me get back to you. It may not run a late enough version of MacOS..........
Carbon and Windows 10? chrisdee Pro Tools | Carbon 59 05-08-2023 03:39 AM
Carbon with anything other than 10.15.7? Matt Hepworth Pro Tools | Carbon 12 01-08-2021 07:14 AM
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 03:14 PM
