Hello everyone, this post is to announce the availability of TL Space 8.0 for VENUE systems. This new version stores the IR library files on the VENUE system’s User partition, rather than the System partition. This change protects the IR library files from being deleted during a system update or upgrade. Note that the full system “Restore" process still deletes everything, including the User partition and its contents; however, the system "Upgrade" option will now leave the IR library intact.
Avid recommends all TL Space users upgrade to version 8.0. We have also posted a new version of the IR library installer which installs the IR files to the User partition. If you have other custom IR files installed, you can exit to the Windows desktop and manually copy the files over or you can use the import menu within TL Space to reinstall them individually. To manually copy the files, locate the desired files in this directory:
Downloads: TL Space-TDM-Edition http://www.avid.com/US/products/TL-Space-TDM-Edition TL Space TDM Edition v8.0 for VENUE Systems TL Space Impulse Response Library http://www.avid.com/US/products/TL-S...sponse-Library TL Space v8.0 Impulse Response Library Installer for VENUE * The IR Library installer is a .exe file that must be run from the desktop, Control-click the "Shutdown" button to exit to desktop. |
when I click on the link to download the Venue file I get this....
You have attempted to access a protected URL which has either expired or is invalid. Please try your download again. If the problem persists, please provide us with the details by clicking here. ?????????????? |
Hi Scott,
All fixed, try again. Sheldon |
You are so on top of things... Thanks Sheldon
Does TL Space IR Library for VENUE include all the other installers on the downloads page?
TL SPACE- Venue | soundsnoop | VENUE Live Sound Systems | 4 | 09-19-2010 06:41 AM |
IMPORTANT-NOTE ON 8.0.3cs1 Update! | TheChimp | Eleven Rack | 0 | 02-03-2010 01:28 PM |
Important update, w/8.0.3 and Win 7 | rqstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-20-2010 04:25 PM |
Pro Tools HD 7.4.2cs2 Update - Important Alert for D-Command Users | Avid | Technical Alerts | 0 | 12-04-2008 01:55 AM |
IMPORTANT SP2 UPDATE BLOCKER | Rail Jon Rogut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 09-04-2004 04:03 PM |
