can\'t change sample rate?
With pro tools HD version 5.3.1, I'm trying to change the sample rate of a session (it has no audio in it yet) but the option to change it is greyed out in both the Hardware Setup and Playback Engine windows. It used to be a simple thing to change sample rate in an open session, now I can't seem to do it at all!!!
HD3 192 I/O Sync I/O G4 800 also, the installer for the 5.3.1 upgrade seems to have overwritten my authorized versions of D2, Sci Fi etc., DPP1 and some of the other plugins I got bundled with HD3 with demo versions. How do I get my authorized versions back?
"this guitar won't play that" |
Re: can\'t change sample rate?
In PT 5.3.1, you can only choose your sample rate while you are creating your session (new session dialog box). Once the session has been created, you cannot change the sample rate.
As for your plugs, if you're upgrading from 5.3, look in the Obsoleted Digidesign Software folder for the older versions of those plugs and drag them into the Plug-In folder inside the DAE folder. -Jake |
Thanks Jake, makes sense about the old plugins folder. What doesn't make sense is not being able to change the sample rate of an open session. That was always an easy option in the past. I have very large and intricate templates setup for certain projects that I get which I now can't use if the sample rate is different than the project I get. Sucks! Digi, why did you take this option away?
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Can't change sample rate | Gabriel_S | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-20-2012 11:43 AM |
Can't Change Sample Rate | jasonschwartz | Pro Tools M-Powered (Win) | 1 | 01-11-2007 11:13 PM |
how to change sample rate?? | remains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-28-2002 04:38 PM |
Change Sample Rate in HD? | Steven Sena | Tips & Tricks | 2 | 08-10-2002 06:33 PM |
