Old 01-20-2004, 03:43 PM
Jotown Jotown is offline
Default Which ASIO driver w Cubase SX and Digi 001
I am using Cubase SX ver 1.6 with the digi asio driver 533b2, and my system seems to be working fine.
I noticed they list the new driver as being funcional as a stand alone driver.
Does this mean I should install the new driver if I am only using my Digi 001 as the sound device for Cubase SX?
I switch between Cubase and PTle quite a a bit.
Is it feasible to load both Digiasio drivers and use one with PTle and the other with Cubase SX?
Is the new asio driver more stable?
Thanks in advance.
Jotown:)
Old 01-20-2004, 04:16 PM
Default Re: Which ASIO driver w Cubase SX and Digi 001
You can't install the 6.1.1 ASIO driver if you have Pro Tools 5.x installed.. it'll break your Pro Tools 5.x installation (read the download section).
You can't use the digi hardware with two apps at the same time.
You can't use the MIDI I/O with the ASIO driver with 3rd party apps unless Pro Tools 6.1.1 is also installed.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
keep losing the asio driver for digi rack 002 in cubase 4.5 nincompoop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-15-2009 07:03 AM
Cubase SX3 +Mbox / ASIO Driver skeeter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-07-2009 02:10 AM
Digi 001 Asio Driver w/ Cubase SL 2.0 Illmatic Tips & Tricks 0 03-17-2004 04:54 PM
Cubase SX and Asio driver under PT 5.3.1 mucky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-29-2003 08:24 AM
DIGI SUPPORT - Is a new ASIO driver for Cubase and The 001 in the pipeline? timyork 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-25-2001 01:18 PM
