Old 12-22-2008, 01:06 PM
kevinpx3 kevinpx3 is offline
Default Plug-ins missing from the multichannel insert menu
This is strange! I am now using Pro Tools 8 and when I try to insert a Waves multichannel compressor on any channel, they are not in the menu (IE: API,SSL). Here is the part that does not add up; the multi mono ones are available in the channel insert menu and they are all available in the AudioSuite. The next odd thing is they appear and work fine in the previous save 7.4 sessions that I am now working with in PT8. The multichannel Waves plugs work fine, I just cannot choose them. I have them in saved session on some channels and cannot add them to another channel. Why would they be in the AudioSuite and not in the individual channel insert menu??? This is driving me nuts to the point that I did a complete reload of Windows and all software. Still missing? Is there a manual way to add plug-ins to the channel insert menu?
Old 12-23-2008, 10:45 AM
64111 Studio 64111 Studio is offline
Default Re: Plug-ins missing from the multichannel insert menu
I am having the exact same problem!! Still trying to figure out a way to get my SSL to show up in the multichannel menu. I use that compressor on all of my vocals!! Installed PTLE8 last night, no dice. If you find out anything, let me know, and I will do the same.
Old 12-23-2008, 12:35 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Bump for kevin...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-23-2008, 12:39 PM
spkguitar's Avatar
Which version(s) of the waves plugins are you using?
Old 12-23-2008, 03:28 PM
Waves Mercury - 5.0
Old 12-23-2008, 04:26 PM
spkguitar's Avatar
~Yeah~
You're going to need to upgrade to the current version (6.0.8 currently, IIRC) to ensure compatibility with PT8.
Old 12-23-2008, 05:45 PM
I just talked to an associate of mine with the waves 6 update. He is having the exact same issue??? He is on XP, PT8, and Waves SSL with update 6 and cannot access his SSL compressor in the multichannel menu, but it is in the AudioSuite. Now what?
Old 12-23-2008, 05:48 PM
spkguitar's Avatar
Your "associate" should post his plugin version list as well.
Old 12-23-2008, 06:47 PM
I told him to set up an account so he can also get some help. Other than the Waves plug in issue, everthing else seems to be fine so far. It will take some time to get through everything with PT8. I will post anything else I find.
Old 12-23-2008, 07:53 PM
I believe he said it Spk...(with all due respect)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Missing Plug-ins from Insert List-PT10 smythmakesmusic Pro Tools 10 0 09-17-2013 12:56 PM
PT8 - Customizing Insert/Plug Menu? Problem.. Pony Slaystation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-11-2009 05:56 PM
Altiverb 6.2 XL missing from TDM insert menu Nitefly Pro Tools TDM Systems (Mac) 2 09-28-2008 05:27 PM
TRacks, factory plug-ins not showing in insert menu, PT7.0 sq2211 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-21-2008 04:59 PM
Reason Adapted missing from Plug-in Pull Down menu brianf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-22-2006 10:55 AM
