Old 10-15-2005, 09:09 PM
jata jata is offline
Default consolidation ?
first let me apologize if this is a silly question ...those who think it is please carry on...
when mixing i often hightlight /seperate a region/ then mute it. ..as a way of muting a track...it's quick for me a couple of key strokes ( apple E/apple M ) and i can be very detailed in my mute in and out...it also allows me to see mutes in the edit window....i hope this makes sense...i know it's probably not the best way of workin...i don't use this method for all my mutes either..like i said it's easy for me to do ...except....and here's the question for those of you that are still with me....when i consolidate a track (to clean up) that has these type of "mutes" i need to delete the muted sections first ( PITA ) otherwise all the "mutes" are played when the track is consolidated ....is there a work around to this ..is this normal...am i normal
thanks for any help !!!!...and thanks to the duc !!!
hd 2 accel /g5 2.0 /6.9.3
Old 10-15-2005, 10:40 PM
Kenny Gioia Kenny Gioia is offline
Default Re: consolidation ?
It shouldn't be working that way.
It should make silence in those spots.
And I use muting the same way as you. I never automate mutes.
Old 10-15-2005, 11:22 PM
(...It shouldn't be working that way.
It should make silence in those spots...)
thanks ...that's what i wanted to know...i'll figure it out from here...
by the way ....i dig your drums...
Old 10-16-2005, 01:03 AM
Consolidate won't follow automation.. but it will mute muted regions.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-16-2005, 01:57 AM
Reitzas Reitzas is offline
I remember on older versions of PT that the muted regions would unmute and become part of the consolidated selection, but that was a long time ago. The muted regions should be replaced by silence.
Just a simple tip. Before you consolidate, make sure you do a playlist of the track. This way if you ever change your mind about something you muted, you can always retrieve that part by referring to the saved playlist.
Dave Reitzas
htpp://www.reitzas.com
Old 10-16-2005, 09:42 AM
thanks again to everyone...as usual always helpful !!!
(I remember on older versions of PT that the muted regions would unmute and become part of the consolidated selection, but that was a long time ago)
-your right dave my mistake ..i guess i've been doin the erase method for a while cause i couldn't find a work around...so i never tried with the newer versions...it works now fine..silence is golden !!!..i'm glad i finaly got around to askin about this !!!
(Consolidate won't follow automation.. but it will mute muted regions)
hey rail thanks for the reply...but it seems the automation still hold after consolidation...
thanks to the DUC ...right on
Old 10-16-2005, 12:24 PM
The automation remains.. but the consolidated track doesn't follow mute automation -- meaning if you automate a mute the consolidated audio will still contain that muted audio -- the only way to create silence (no audio data) is to create a region and mute it. The first post in this thread indicated that you felt that automation mutes should affect a consolidation. All that consolidate does is run the Gain AudioSuite plug-in for you (with a unity setting) and replace the region selected.
Rail
Platinum Samples
Fades on Consolidation sszeryk Tips & Tricks 2 05-20-2010 09:47 AM
Consolidation GloryIsSilent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-08-2009 02:55 PM
Consolidation? Rome630 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2006 06:26 PM
Track consolidation bug? Jaysus Pro Tools TDM Systems (Mac) 5 04-30-2006 11:35 AM
consolidation sid rosen Tips & Tricks 2 11-12-2004 12:28 AM
