Old 07-20-2021, 01:42 PM
bengineer bengineer is offline
Default Update 7.3 TDM to 12
A couple of years ago I bought an PT HD upgrade for PT 12 with an activation card and iLok. For various and mostly useless reasons and excuses, I never did the upgrade, but would now like to.
Current system is PT 7.3 HD2 on a 2006 cheesegrater and 192's for the interface. I've read threads here and all over trying to find out if I can upgrade using this gear, or do I need to purchase HDX cards and interfaces.
Advice is appreciated.
Old 07-20-2021, 10:56 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Update 7.3 TDM to 12
TDM cards only go up to 10.3.10, if you want 12 you need HDX
Janne
Old 07-21-2021, 08:28 AM
Thanks, it helps to hear it directly from someone who knows!
Ben
Old 07-22-2021, 08:21 AM
But the 192's will work on the newer cards(HDX and HD/Native). Since you have the cheesegrater, a used HDN card(around $700) might make good sense.
Having said that, what are the specs of the Mac and is it compatible with PT12?
Old 07-23-2021, 11:26 AM
I've been looking for one, that price is not too bad. I'll keep at it. Right now I'll go to 10, but I'd rather go to 12.
thanks!
Old 07-23-2021, 11:30 AM
Also, Dave, I meant to add, if I upgrade only to 10, I can keep this Mac 1,1 and upgrade to OS 10.6, I've already added 16GB memory.
If I can find an HD Native card, I'll need to get a new cheesegrater to get all the way up to 12. So, I'd be looking at a 5,1, at least 16GB memory.
I had not realized that an HD Native PCIe card would do what I needed. I kept thinking I would need an HDX capable I/O along the lines of a new model 192.
so, more research is required. Thank you!
Ben
Old 07-23-2021, 12:34 PM
Ben
The reason I asked about your computer specs is because an early Mac Pro(and 1,1 is certainly early) may not have enough horsepower to run an HDN rig. If you can find a deal on a 5,1 with at least a 6-core @ 3+ GHz and 32GB of RAM, that should do a solid job with HD/Native. This is based on my own success with a 6-core PC(same specs). If you're not married to Macs, a used HP z820 12-core can be had for barely over $1K and those are solid as a rock. 3 years ago, I ran a commercial studio in Nashville with that setup and loved it. The computer was a used z820 with dual 6-core XEON's at 3.5GHz, 64GB of RAM and a GeForce 750Ti graphics card. It ran Windows 10 and PT 2018HD with a pair of 192's and a pair of HD IO's. I tracked 32 inputs and sent 6 stereo headphone mixes(from the sessions) with plenty of plugins with a 64 buffer setting(low latency) day in and day out(I would expect similar with a 5,1 12-core at over 3GHz, but the hp cost me $1100, shipped to my door)
Old 07-23-2021, 01:56 PM
I'm thinking I might be stuck here- the upgrade I currently have and want to use is for 10/11/12 and a perpetual license. I could ditch that idea and go HD Native (I assume that's a non-perpetual license). Maybe that's a thought down the road, I'm still thinking....
Yessir, I've known that going to 12 would mean a new(er) computer, and I'm good with that. Your specs listed above will be most helpful in the search. I'm kinda tied to Mac, it's been good for me for a very long time.
But, just to be clear, you're saying and HD Native PCIe card will run a pair of TDM-era 192's? I use the extra outputs to drive a 16 channel cue system, and I'd rather not have to deal with latency issues for headphones.
Thanks so much for your response, this has been quite the journey. Next time, I'll just rob a bank and go all the way.
Old 07-23-2021, 03:29 PM
JFreak's Avatar
Yes original Mac Pro models are supported until 10.7.5 which means you can use TDM cards with latest PT10 release, but if you want anything more current you will need to get more current computer and more current card(s) either HDN or HDX to keep using your 192 interfaces.
Janne
Update Module Firmware message after 3.7 update WildHoney Avid S4/S6 1 10-21-2017 11:28 AM
10.3 Update - Windows shutdown issue has returned. Update at your own risk. crm0510 Windows 14 09-19-2012 01:50 PM
10.5.6 update. Is it safe to apply the system update from 10.5.5? SBCCMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-02-2009 02:27 AM
Windows Update Vs Apples Software Update sunburst79 General Discussion 2 07-14-2007 06:40 AM
What is this Apple Update? Hard Disk Update...ver 1.0 McMasters Pro Tools TDM Systems (Mac) 1 06-30-2003 05:56 PM
