Audiofinder
Just a small heads up for everybody:
Audiofinder has just gotten a "spot to protools" option. Get over to icedaudio.com and check it out. No, I donīt work for Iced. I just root for the small guys (or application in this case) and have been using it for years.
Newest Pro Tools on mac & pc. |
Re: Audiofinder
does it search metadata?
Re: Audiofinder
Indispensible tool. Renames files, Makes EXS instruments from SFX files, Great search, finder integration, DSP features etc etc etc etc..... Great price, great support, Worth the price. I would not hesitate to add it to my Audio tools, now with spot to Tools, better than brilliant!
my 2c Simon L. |
Re: Audiofinder
is it also possible to spot a selection out off a region/audiofile to PT??
TIA! Quote:
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
Re: Audiofinder
Yes, it can spot parts of a sound file onto the time line.
I donīt use meta data. All our Audio has the entire description in the file name. (really really long file names) This I found to be the simplest way of having a cross platform compatible SFX archive. One problem with the spot feature is that AudioFinder leaves the edited copy of the file in the folder where it found the file, not in the audio files folder of the session. This would leave a lot of clutter around on the SFX archive. My work-around is to set the "processing output folder" to a folder in the system disc. I then in PT set the system disc to transfer only. This makes PT import the file into the session adio folder. All is then good. More or less...
Re: Audiofinder
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Audiofinder
Wikipedia:
http://en.wikipedia.org/wiki/NTFS Short version: Maximum 255 characters. The only times I have trouble with the length of a filename on a PC is when the file is located several folders "down" in folders with really long names. Typically appears when unraring stuff from torrents. Actually Iīve had more problems with the length on macs, but I canīt remember what that was about. Possibly something about PC to mac and back or something.
Re: Audiofinder
Not all PC drives are formatted NTFS. Not if you want to write to it from OS X on a pre-intel machine anyway. I know there are solutions for the Intel Mac crowd.
Fat32 has a limit I believe... I will wiki it on my own,
Ray Trujillo Freelance Audio Engineer Last edited by FajitaTone; 09-28-2009 at 06:45 AM. Reason: spelling |
Re: Audiofinder
But maybe they have fixed this in PT8. PT is pretty meta-data-transparent. It preserves the meta-data unless you audio-suite something. Then PT strips out all the info. frank.
Re: Audiofinder
Not sure if it's something with my PTLE8.0.1 stage rig but I got a couple of PT hangups on Saturday after using Iced's newest spot to PT function. I will see what else may have caused this but it happened twice after trying out the spot to PT function. If someone else could second this we should let Iced know ASAP...he is fantastic about his bug fixes. AF is the only thing I use on my laptop rig since I don't want to haul yet another key around with me to run Soundminer.
Wilson Dyer mpse Sound Supervisor, NCIS Los Angeles
My day job: Wilson Dyer MPSE Sound Supervisor: NCIS Los Angeles, CBS Television |
audiofinder and protools | fork-media | Post - Surround - Video | 6 | 07-17-2013 10:19 PM |
audiofinder? sound design | dubbs718 | Post - Surround - Video | 18 | 11-27-2006 08:16 AM |
Audiofinder users? | lwilliam | Tips & Tricks | 1 | 01-30-2005 08:42 AM |
