QuickTime Pro question
I have QuickTime Pro on my computer, but I have recently upgraded to Pro Tools 8. I now have two system drives on the computer.
I have a movie that I am able to play when I boot from 10.4.11 with QuickTime Pro Version 7.6.2 (1327). When I boot from 10.5.8 and try to open the same movie with QuickTime Pro version 7.6.4 (1327.73) I get this message: The movie could not be opened. The file is not a movie file. It has the same QT logo and is the same file. Am I missing a component in the new system? I can open in the old system and then export the movie, but that will take quite a lot of time. The movie is over two hours of a live concert that I'm mixing. I could mix it in 7.4 but what fun is that??? Thanks in advance. Steve
Steve Shepherd Extreme Mixing |
Re: QuickTime Pro question
Do it in 7.4 to day, and let it convert over night. Then continue in 8 tomorrow. Not a high tech solution, but will let you work.
Newest Pro Tools on mac & pc. |
The Quicktime Pro which u have is Cracked???? if so then the code is for tiger only and not for leopard you will have to check for QT pro code for leopard..
HIMANSHU |
He does not say that it was with a cracked verion of QT. Anyway the moviefile should have played fine. The main difference between standard and pro is export options, not playback.
Simply check the folders that contain the movie to see that there isn't a "/" oe a ":" etc in the folder name. hope this helps Simon L. |
+1 sleadley, had the same problem and the same solution cured it, avoid illegal characters at all cost.
Sorry it's so long getting back. It seems that the .mpg file needs a video component in order to play. It didn't used to in my older version of Quicktime. So, I bought it online from Apple for 19.99. I do own my copy of QuickTimePro, so that's not the problem.
Here's a link to the codec. http://www.apple.com/quicktime/mpeg2/ It plays, but it's still a bit of a drag because (a) it won't import the Audio with the movie. It asks me where I want to put it, then does nothing. The other problem (b) is the playback of that video inside of Pro Tools is really bad. Too jerky to be useful. It's fine in Q T Pro. I imported the audio and video separately, but I think I should open the file again in QT Pro, and export the whole thing as something more friendly to PT. What would your advice be on that format? I can have my laptop do this while I get started on the mixes with what I have. Thanks for all of the replies. Steve
MPEG needs the MPEG2 playback component which needed to be purchased from Apple. It also could have been installed with any number of bundles - like the FCP bundle, DVD Pro, etc.,
You probably have it installed on the one partition and not the other. Look in the System/Library/Quicktime folder for the QuickTimeMPEG2.component You can make a copy of it and move it to the other partition (as long as you have admin privileges). |
Thanks Jim. You had the right answer. I just bought it again and installed it. Not sure where it would have come from on the other drive. I've never installed Final Cut or DVD Pro. I do have Logic Pro, but it's working on both set ups.
What is the best format to export for Pro Tools so that I can get the stereo audio into Pro Tools in one shot? Steve
QuickTime question | CLee | Pro Tools TDM Systems (Mac) | 3 | 05-25-2010 12:07 PM |
Quicktime question on PB 550 with OS 10.3.9 PT 6.9 | sukks2bu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-10-2006 09:30 AM |
Quicktime Pro 7 question | trakbytes | Post - Surround - Video | 12 | 07-19-2005 12:19 AM |
Quicktime question | beech | Post - Surround - Video | 8 | 08-22-2002 12:17 AM |
QuickTime question | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-21-2002 01:54 PM |
