  #21
Old 05-02-2022, 09:21 PM
smurfyou smurfyou is offline
Default Re: Pro Tools 2022.4 Crash Move To New Folder (Routing Folder)
Working here on an existing session.
Mac mini 2018 i7
Catalina 10.15.7
PT2022.4 Ultimate native with RME
~Will
  #22
Old 05-03-2022, 07:15 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Tested it here on my PC Hackintosh. Both on macOS 10.15.7 and Windows11.
Working as expected on existing and new sessions. During playback and with the transport stopped.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
  #23
Old 05-06-2022, 05:56 AM
thebeatless thebeatless is offline
Default Re: PT 2022.4 crash moving tracks to new Routing Folder [PT-286068]
Occasionally I forget about this bug and it allows me to create a new routing folder without a crash, but normally it crashes.
As a workaround I've been selecting the tracks I'd like in a routing folder, hold option + shift to assign the outputs of these tracks to a new track (Aux). When I do this, it creates a new Aux, but routes the new aux's output to it's input instead of setting it to my session's set default output. Clearly not a desirable result! I then have to change the output, right click the aux to turn it into a folder, and drag the desired tracks into the folder. What a hassle!
  #24
Old 05-06-2022, 09:07 AM
Ceeze Ceeze is offline
Working fine for me with Pro Tools Ultimate 2022.4 on a 2019 iMac with macOS 11.6.5. I did notice however that if I hit undo after creating a basic or routing folder, the folder track doesn't go away.
  #25
Old 05-07-2022, 03:37 PM
jakemiller jakemiller is offline
This is consistently happening to me on an i9 MacBook Pro running PT Ultimate, latest Monterey with any playback engine.
Also consistently happening on an iMac Pro running Pt Ultimate on latest Big Sur and HDX 2.
Driving me insane. Multiple other friends/colleagues are also experiencing this and complaining in the group chat ��.
  #26
Old 05-09-2022, 05:54 AM
JohnRivers JohnRivers is offline
Same problem here! 2022.4 has been an absolute nightmare so far. Creating routing folder in old or new session causes instant crash. Really annoying!! Also generally slow and sticky.
  #27
Old 05-12-2022, 04:27 PM
Dizzi45Z Dizzi45Z is offline
Okay, So I have a session file where this consistently happens:
Session File
When you open it, try to "Move to New Folder" the three string tracks that are highlighted and use a stereo routing folder and Pro Tools should crash.
Let me know if everyone else has this crash on their systems too.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
  #28
Old 05-12-2022, 05:24 PM
Session File
Works here without crashing.
Mac mini 2018 i7
Catalina 10.15.7
PT 2022.4
~Will
  #29
Old 05-13-2022, 02:37 AM
Cacov's Avatar
Cacov Cacov is offline
Session File
Have not been able to reproduce your crash, routing folders seems to work fine here.
Mac Pro (Late 2013)
macOS Mojave 10.14.6 (18G9323)
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022
Sound Engineer | Non-Avid Employee
  #30
Old 05-15-2022, 08:40 AM
aidyhall aidyhall is offline
Yep, crashes for me when trying to use the shortcut to route tracks to a new routing folder. Have to create a blank folder track, and then manually route the audio tracks. Shortcut definitely used to work, so this is a new bug for 2022.4
Mac Pro 2019 7,1 12-core 3.3Ghz, 96GB RAM, macOS Ventura 13.6
ProTools HDX Ultimate 2023.12
Avid HD16 i/o, Digidesign Blue 96i/o
UAD Octo PCIe, UAD Octo Thunderbolt 3 Satellite
www.adrian-hall.com
2022.4 solo safe aux tracks? ejsongs Pro Tools 22 07-07-2022 02:23 PM
Frames on Video tracks not displayed in 2022.4 JoeTools1963 Pro Tools 8 05-28-2022 06:17 AM
2022.4 Bug when grouping tracks into a stereo folder bobbriessinck macOS 5 05-21-2022 06:02 AM
2022 update: routing Mac Built-In audio to PT? Eric Lambert Pro Tools 27 05-13-2022 12:41 PM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
