HELP PLEASE.........TOO LONG TOO DESCRIBE HERE
Hello all.
I am using PT V.5.1.3, and I recorded a stereo audio track into PT @ 16/44.1 wav file, and it stores the audio as seperate .L / .R files. When I go to burn the CD , my software ( adaptec Jam 2.6 ) cant burn the split mono wav file.It will burn split mono SDII files but not the wav. Is there a way to record directly into PT as wav files that will be in a burnable state? or will I have to bounce to disk and sum the mono audio files to a stereo wav file. I hope not cause that would sukk. Thanks all
Powermac 9600/300 768mg ram OS 9.1.2, PTmix3 V5.1.3, 888/24, Adatbridge, 882/20, PSX-100, BigBen MacBookPro 1.8ghz 2gig ram OSX tiger, Mbox2 PT V.7 |
Re: HELP PLEASE.........TOO LONG TOO DESCRIBE HERE
Once you have the audio in PT all you have to do is select your L and R files, then export them as a stereo interleaved WAV. No real time BTD is required.
-S0nguy |
When you create a session you are given the choice as to which audio file format you want to use, but Pro Tools will only handle multiple mono, not stereo audio files. All you need to do in your situation is select the audio that you want to burn and choose "export selected as files" from the regions list menu. This will give you the option of copying the audio files as whatever format you need to burn (usually stereo SDII 16 bit 44.1).
--Andy |
Thanks guys, That is what I thought. Have a good day all
Describe your studio monitoring sends setup | starburst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-03-2007 10:56 AM |
OT...can You describe the sound... | lemix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-27-2004 02:10 PM |
Describe BTD Alternative Method? | s0nguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 04-02-2004 11:40 AM |
Please Describe Harness Problem | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-03-2003 01:36 PM |
Too long for comfort... problems with long session files | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-20-2001 06:51 AM |
