**PT10 Bug - Pencil Tool/Clip Gain
Found a bug today.
It appears that the pencil tool doesn't recognize clip gain. See video: In order to fix this click, I had to reset the clip gain to zero, draw it out, then raise it back up. |
Re: **PT10 Bug - Grabber Tool/Clip Gain
See "what´s new" manual. Under certain conditions clip gain is rendered into the file when using handles. Maybe that is the case when destructively editing with the pencil as well? Not sure. Maybe it´s related..
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: **PT10 Bug - Pencil Tool/Clip Gain
This is one of those things in PT10 that needs to "just work". I'm not going to go through multiple steps to simply draw out a tick.
Curious if anyone else has had this issue? |
Just out of curiosity, why not hit "-" and go volume and pencil it out? and how is clip gain more efficient over just going to volume and using smartools to draw/bring up or down volume? |
As far as the pro/cons of clip gain, that's just a matter of taste. I prefer it since you don't have to constantly jump over to volume automation and hear your faders jumping around through a session. |
Toggling between "T" & "R"? |
Yeah, that's exactly what I was trying to do, but the clip gain is messing up the process. (see the video I linked)
OK, just watched the video. I think we're seeing the same issue. Pencil tool shouldn't have anything to do with clip gain, or it should override clip gain. This latest behavior makes it unusable. |
BTW, I think the point about it being related to clip gain is well taken in my case. I'm working on a 6 hour long forensic audio file taken from an MP3 recorder. Often, the audio has to be raised by 24 dB, de-noised, de-clipped and de-crackled using iZotope RX and then whatever thunks or clicks have to be dealt with manually. The pencil tool seems to be applying another 24 dB of gain to the drawn-in data, so in my case, it flies right out of the track. In my case, gong back to zero wouldn't work because I'd not be able to find it! In this case we're talking about the worst s/n ratio I've ever heard.
I experienced the same bug: Pencil tool on waveform in a region (ops, clip! ) with clip gain and the gain is applied one more time after the drawing.
I'm used to consolidate the part of region I need to "pencil", and so this solve the problem, but this is pencil bug is extremely annoying. OT, but one thing I think should be changed is the way consolidate works: consolidating only a part of a region should retain clipgain and metadata (or an option to choose this behavior should be available), matching the way duplicate AS plugin works. Best Davide |
Pencil Tool- Wave Form Editing in PT10 | mauiboy | macOS | 2 | 06-13-2012 01:35 PM |
Pencil tool and Clip Gain | mattrixx | Pro Tools 10 | 2 | 03-15-2012 09:43 PM |
Clip Gain and Pencil - Bug | tj_davies | Pro Tools 10 | 3 | 02-06-2012 03:27 AM |
PT10 Clip gain bug? | dterry | Windows | 0 | 10-23-2011 12:11 PM |
clip fixes with pencil tool | davidp158 | Tips & Tricks | 3 | 03-29-2001 07:23 AM |
