Old 11-05-2010, 05:30 PM
TonyFla TonyFla is offline
Default 'Audio Midi setup' problem since installing SL & PT9
I installed snow leopard & PT9 today.
The midi part of 'audio midi setup' doesn't see the 003 as a midi interface, so i'm having trouble sending midi in.
Got my rd700 working for a while on usb but rebooted & did'nt work again.
Any solutions? thanks.
Old 11-05-2010, 05:39 PM
AvidCS's Avatar
AvidCS AvidCS is offline
Default Re: 'Audio Midi setup' problem since installing SL & PT9
Does Pro Tools see the 003?
Old 11-05-2010, 05:48 PM
Yep. Everything working fine in PT. 003 is recognised.
Think the problem is audio midi setup. It doesn't show the 003 as a midi interface so I can't connect external devices to it.
Got it to work briefly but back to square one now
Old 11-06-2010, 10:00 AM
PittsburghsRECLabel PittsburghsRECLabel is offline
Did you install the new drivers for 003R PT9?
Old 11-19-2010, 05:21 AM
Wayne Dawkins Wayne Dawkins is offline
I am having the same issue. Waiting for tech supp to reply they Tested and qualified the new 2010 macs to work with PT9
http://www.myspace.com/waynedawkins
Old 11-19-2010, 11:18 AM
markmeil markmeil is offline
I just updated to PT 9 and I'm having a MIDI issues as well.
Clean uninstall of PT8LE
Full Install of PT9
Updated 003 Drivers
Audio works fine through the 003
003 is listed but grayed out in Audio MIDI Setup
MIDI light flashes on 003 when keyboard is played, but no signal gets to PT
The only issue i can find is that I updated to 10.6.5 (in the process now of reverting to 10.6.4)
What system are others with this problem running?
**Edit: I see now in the other thread that some are having this trouble on 10.6.3 & 10.6.4 as well.**
Any help would be appreciated.
Mark
iMac (14,2) 3.5 GHz Intel Core i7 (Late 2013)
32 GB RAM - OS 10.9.1
Pro Tools 11.1.2 - Digi 003
Old 11-19-2010, 12:14 PM
crizdee's Avatar
crizdee crizdee is offline
Ty this,
Unplug the 003 or midi interface
trash the AMS prefs user/library/preferences com.audiomidsetup.plist
turn off the mac
plug the interface back in
Now see if it detects the interface!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-19-2010, 01:16 PM
Thanks Chris,
but still no luck...
Mark
Old 11-19-2010, 02:13 PM
Ok,
All is working now.
When I originally updated the drivers, I did it before installing PT9. (Which is what I thought it said to do)
I reinstalled the PT9 003 driver updater again and now things seem to be working.
Hope this helps someone else...
Mark
Old 11-23-2010, 08:58 PM
Wayne Rose Wayne Rose is offline
Glad everything is working as it should for you.
Is the graphic aspect of AMS working properly? I am running PT 8.0.4, and just upgraded to OS X 10.6.4 from 10.5.8 yesterday.
Everything seems to be working. However, the AMS Midi screen will not update when a module is moved with the mouse. After closing AMS and opening it again, all the modules line up along the top of the screen.
A search in the web shows this to be a common problem, though I can't seem to find reference to it on the DUC.
There are actually three pref files related to AMS (2 plist, 1 mcfg). Have trashed them several times, and rewritten part of the mcfg file using PrefEdit with some benefit, but still have not solved the screen positioning problem.
There are also several plist files in the AMS package contents resources folder, but I'm staying away from those until I learn more.
Any thoughts? Anyone?
[IMG] code is Off
Problem with Speaker Configuration in Audio Midi Setup HB123 Pro Tools HDX & HD Native Systems (Mac) 0 01-18-2014 02:44 PM
Audio Midi Setup, Multichannel Audio Problem soundeditor76 Pro Tools 10 0 04-13-2012 04:49 PM
Audio Midi Setup issue..PT8 or OS10.5.5 problem? postmike MIDI 2 01-22-2009 04:30 PM
Audio Midi Setup problem netz11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2007 08:22 AM
Audio Midi Setup Problem Muzoid MIDI 1 09-26-2005 11:26 AM
