Old 09-26-2005, 10:46 AM
Muzoid Muzoid is offline
Default Audio Midi Setup Problem
I just recently had to format the hard drive on my powerbook and re-install the Mac OS (10.4-10.4.2) in order to get Logic back up and working which happily it is. I had backed up the drive and used "migration tool" to retrieve my user data and network settings after the initial Tiger install - I mention this as it's probably related to my current problem. The problem is that Audio Midi Setup doesn't see my Midi interface (Unitor 8 mk II) when I scan with it and when I choose to add a device, none of the manufacturer and model choices are available. I'm sure this is a simple fix and would appreciate any help. Thanks.
Old 09-26-2005, 11:26 AM
Stig Eliassen's Avatar
Default Re: Audio Midi Setup Problem
Hi.
Check this thread.
http://duc.digidesign.com/showflat.p...fpart=1#886402
Problem with Speaker Configuration in Audio Midi Setup HB123 Pro Tools HDX & HD Native Systems (Mac) 0 01-18-2014 02:44 PM
Audio Midi Setup, Multichannel Audio Problem soundeditor76 Pro Tools 10 0 04-13-2012 04:49 PM
'Audio Midi setup' problem since installing SL & PT9 TonyFla Pro Tools 9 11 11-24-2010 01:06 AM
Audio Midi Setup issue..PT8 or OS10.5.5 problem? postmike MIDI 2 01-22-2009 04:30 PM
Audio Midi Setup problem netz11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2007 08:22 AM
