Old 07-24-2021, 02:53 PM
protoolsuserman protoolsuserman is offline
Default 96io not recognised by pro tools 11 anymore?
Hi
Pro tools won't let me in anymore with my 96io connected.
I figured it could be a firmware issue, so attempted to update the firmware and get the following message each time..
Please see attached image
Programming failed
Data verification error on flash sector 9
Anyone heard of this and know how to fix?
I know it's not the cables as have swapped with my other system and all works fine.
Just hoping the interface isn't bricked
Thanks
Rob
Sent from my CPH1917 using Tapatalk
Old 07-24-2021, 03:15 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: 96io not recognised by pro tools 11 anymore?
Which OS? PT11 is supported up to OSX 10.10 and Win 8.1
Janne
Old 07-24-2021, 03:25 PM
Yosemite
It worked fine before
Old 07-24-2021, 03:44 PM
JFreak's Avatar
If nothing has changed software-wise, then I suggest you clean the connectors of your DigiLink cable. If you do not have industrial alcohol available, juggling with the connector a dozen times should do it at least for a while.
Janne
Old 07-24-2021, 04:17 PM
If you're sure its the 96 IO that is bad, toss it out and buy a used 192. It'll be the cheapest upgrade ever
Old 09-17-2021, 02:40 PM
scenaria scenaria is offline
I’m this is the third person I’ve seen with a firmware failure. All revolving around 2021.7 . I had the same result trying to update my Omni. Now it’s bricked and avid wants $1000 to rma it. Seeing that this has happened on other devices other than the Omni and it hapoened with 2021.7… I’m starting to think Avid messed up. Thoughts ?
Old 09-17-2021, 02:59 PM
JFreak's Avatar
Do you have that in writing? To my knowledge Avid is not repairing DigiDesign branded interfaces.
Janne
Old 10-26-2021, 01:53 AM
Whatever you do
DO NOT perform firmware updates to old blue faced hardware with modern versions of pro tools.
You WILL brick them.
You have been warned.
l
FS: Pro Tools HD3 PCIe + Digidesign 96io Mihael Hercog Buy & Sell 1 12-21-2013 09:44 PM
HD1 Core PCIe, 96io, Pro Tools LE DV toolkit Rikk Buy & Sell 0 06-27-2013 04:32 AM
Axiom Pro 49 not recognised by Pro Tools 8 Eludis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-25-2012 09:09 AM
Outboard Gear > Pro Tools 8 > 96io KINGDRAGON Pro Tools TDM Systems (Mac) 8 09-10-2010 05:33 PM
24Bit aif not recognised by Pro Tools TnglewdStu Digidesign Hardware & Software 2 07-30-2002 05:59 PM
