Old 01-07-2008, 02:08 PM
jimbojimbo jimbojimbo is offline
Default How to add more bars before zero?
so I've recorded a song but need to put things at the beginning - I usually leave space just in case, but this time it wasn't enough.
I don't want to 'select all' and shuffle everything up because won't that mess up the automation?
So is there a way to add bars at the beginning?
It's easy to do with Logic, you just drag it into the minuses but there doesn't seem to be the option on Pro Tools!
View my website:
James Arter Music
www.jamesarter.com
Soundcloud
http://www.soundcloud.com/happybunnyproductions
Old 01-07-2008, 05:29 PM
flommer flommer is offline
Default Re: How to add more bars before zero?
Perhaps
Event>Time>move song start...
haven't tested it so I'm not sure about the automation or other options. Try before you buy..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 01-07-2008, 05:32 PM
emorganproductions emorganproductions is offline
there is a feature called "Insert Time", I think you can find it in the Event menu, I can't remember off the top of my head and I'm not in front of my rig. Move your playback cursor to the start of your session and go Event-time operations-insert time and you'll get a window like this.
http://www.soundonsound.com/sos/jan0...rotools7.l.jpg
You can add an extra 8 or 16 bars, whatever you need, and all your automation, tempo changes, and markers will shift over with the audio.
Hope that helps
Evan
Click me...
MacBook Pro 2.8 GHz intel i7, 16GB / OSX 10.10.5 / PT 11.3.2 / UA Apollo
Old 01-07-2008, 05:33 PM
'Insert Time'.
filosofem
Aaron Mulqueen - 001 HD Native
Old 01-07-2008, 05:51 PM
ah sweet!
thanks guys, I'll check it out..
View my website:
James Arter Music
www.jamesarter.com
Soundcloud
Old 01-07-2008, 06:24 PM
sinukus sinukus is offline
If you select Options->Automation Follows Edits - then automation will follow what ever you do in shuffle mode.
Below Zero Beats on 92.7 FM San Francisco
Sundays 8pm - Midnight
http://belowzerobeats.com
Old 01-08-2008, 02:10 AM
aha, another good tip...
Thanks mate!
View my website:
James Arter Music
www.jamesarter.com
Soundcloud
Old 01-08-2008, 05:06 AM
dogon dogon is offline
select all and press option+H
A "shift dialog box" will come up....
set amount of bars
off you go
Old 03-29-2011, 11:21 AM
fifthflaw fifthflaw is offline
great tips! sorry to resurrect an ancient thread but is there a way to do this which moves the markers at the same time?
Old 03-29-2011, 11:26 AM
guitar486 guitar486 is offline
Insert Time will "move" everything as stated above. opt + 1 to bring up the Time Operations window then select insert time from the drop down.
----I was thinking of taking a solo in the bridge.
-Nah, I don't think that would sound good.
----Ok, well how about just a series of cool riffs?
Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK
Bars and Beats GTTTT Pro Tools 10 4 04-05-2013 04:51 AM
help with bars and 7.4 hodge Tips & Tricks 10 03-20-2010 09:35 AM
Add bars Soundtrack2life Pro Tools TDM Systems (Mac) 2 12-18-2009 09:23 AM
Delete 20,000 bars!!! Sagane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-01-2004 08:27 AM
OT: Bars on a sequencers vs. Bars for a writer DEVIZE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-01-2003 12:35 AM
