The following Pro Tools TDM CS update is available from the Support->Downloads->Index of CS Fixes:
http://www.digidesign.com/download/cs/ Pro Tools TDM 6.9.3cs1 for HD Systems on Windows XP Updates Pro Tools TDM 6.9, 6.9.1, or 6.9.3 software to Pro Tools TDM 6.9.3cs1 for Windows XP What's Fixed in Pro Tools TDM 6.9.3.cs1 for Windows XP? Fixed: The Key Command Sequence for Fine-Tuning Automation Breakpoints Had Changed (Item # 65387) • The "fine-tune breakpoint" Control key functionality has now been restored to the pre-Pro Tools 6.9 behavior. The key command for "Write Level Constrained to Next Breakpoint" (new to 6.9) has been changed from "Control-click" to "Alt-Shift-click." The key command for "Write Level Constrained to Previous Breakpoint" remains "Control-Alt-click." Fixed: After Several Hours Of Continuous Working, Pro Tools Could Slow Down Or Stop Responding (Item # 58423) • A low-memory condition could be created by repeated stops and starts over a several hour period, causing the slowdown, or eventual crash. Fixed: When Using Mojo Or V|10, "Not Responding" Errors Could Result In Having To Force Quit (Item # 66959) • Working continuously for as little as 30 minutes could cause this error. Fixed: When Using Serial Timecode, Pro Tools Would Sometimes Lock with an Offset When Using a Tascam DA-98 (Item # 64636) • The Tascam DA-98's servo lock bit behavior would cause Pro Tools to think the DA-98 was servo locked before it actually was. This would cause inconsistency when Pro Tools locked to serial timecode generated from a DA-98 or other devices with this same servo lock bit behavior. Fixed: A ProControl Fader Could Sometimes Lose Communication with Pro Tools while Writing Automation (Item #61458) • While writing automation, a ProControl fader could lose communication with Pro Tools, resulting in no automation written for the time the lapse occurred.
Administrator Avid Pro Audio Community |
after installing this cs update, protools says:
protools 6.9.3 ![]() this application has failed to start because vedioif.dll was not found. re-installing the application may fix the problem tried reinstalling the cs update and still get the error any ideas? thanks in advance! |
I'm getting the same problem. Did you hear from Digi or find anything out?
I don't know how many TDM users on PC there are out there. Are you a Beta tester? <M> |
I have the 6.9.3cs1 installed and dont have any problems...GOODLUCK.
hi guys
i still have this problem and have not heard anything from digi on it i click ok when i get the error and protools continues to load and work fine just kind of a pain nope, i'm not a beta tester either thanks! |
I'm sorry we don't have any specific info on how to fix this.
I think the best thing to do would be to uninstall and reinstall Pro Tools and the update, to see if that clears up the problem. |
Has anyone tried reinstalling the whole program yet?
Just letting everyone know, reinstalling everything from scratch does not help the "unable to locate component this application has failed to start because vedioif.dll was not found. re-installing the application may fix the problem" Error. Whats next??
I've had 6.9, ran 6.9.3cs1 installer it requested uninstalling 6.9, i've uninstalled it , ran 6.9.3 and it works. cannot reproduce your problem sorry .
Just wanna do music, RA. |
I installed 6.9.3cs 1 right over 6.9 and it didn't ask me to uninstall. Starts up fine for me, and apart from some strange graphic glitches it seems to work fine so far. I'm still using WinXP SP1.
8.0.3 and 8.0.3cs1 Update Issues | kingg67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-14-2010 10:19 AM |
IMPORTANT-NOTE ON 8.0.3cs1 Update! | TheChimp | Eleven Rack | 0 | 02-03-2010 02:28 PM |
8.0.3cs1 update...now PT won't load... | ronwasserman | Pro Tools TDM Systems (Mac) | 8 | 01-22-2010 11:14 AM |
Pro Tools TDM 6.9.3cs1 Update | Avid | Pro Tools TDM Systems (Mac) | 20 | 09-20-2005 09:53 AM |
Pro Tools TDM 6.2.3cs1 Update | Avid | Pro Tools TDM Systems (Mac) | 1 | 03-04-2004 10:30 AM |
