Hello I have a Behringer X-touch one that is daisy chained to an X-Touch Extender. They are able to communicate with Pro-Tools but the issue that I am having is that when the devices pull the track info, the first 8 channels will go to the X-touch one and the X0tender will pick up tracks 9+. Is there a way to get it where the extender picks up on track 2 and not track 9. And when I say tracks 1 or tracks 9 I am talking about the order they are listed from top to bottom in the mix window. Thanks in advance.
HUI wants to bank in 8 channel increments. I'm not sure you can do what you want. Is the Extender meant to work with the Xtouch One or just the regular Xtouch?
~Will |
This^^^ is also what I would expect. But having said that; its easy to make changes to the settings, so you can try changing the X-Touch One to 1 instead of 8(not sure what will happen, but its easy to test). If that doesn't work, try disconnecting the X-Touch One and setup only the 8-fader unit and see if that works by itself. As smurfyou says, the extender might not work in this configuration(IOW, it may require the full-sized X-Touch instead of the "One")
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Behringer X-Touch Faders | djohnson223 | Third Party Interfaces | 11 | 01-13-2022 10:30 AM |
Behringer X-touch issue | secret studios | Pro Tools 12 | 4 | 10-23-2021 05:38 AM |
Behringer X-Touch or Presonus Faderport 8 or ..? | JBQIII | Pro Tools 12 | 11 | 08-20-2017 08:28 PM |
FS Behringer X-Touch | brianjanthony | Buy & Sell | 0 | 05-26-2017 06:42 AM |
Behringer X-Touch | peter5992 | Third Party Interfaces | 1 | 02-04-2015 10:56 PM |
