Using Eleven rack to run Bias FX/VST
Hey guys, I recently tried using my Eleven rack as an audio interface to run Bias FX and it works fine.
However when I was playing (with direct monitoring), I can hear both the dry guitar signal and the wet signal from Bias FX and it's slightly annoying. I'm not sure if ordinary audio interfaces faces the same issue as I have not owned one before or do i have to turn off something from the eleven rack or through my DAW. Thanks in advance. |
Re: Using Eleven rack to run Bias FX/VST
The key missing thing here is what DAW are you using? Only Pro Tools mutes the internal monitoring path of the guitar rig in the Eleven Rack.
But if you just want the dry guitar track to feed your DAW/Bias FX plugibs then set that track input in the DAW to "Guitar In" and the Eleven Rack Rig Input (in User Options) to some unused input, say Reamp. |
I had the same issue with another brand of plug in. I'm not familiar with bias but if it runs in dual amp mode make sure both amps are switched on.
Eleven Rack + ERXP Pro Tools 9 Windows 7 Gibson Guitars Washburn Guitars Michael Kelly Guitars Yamaha Bass Roland TD30K EZ Drummer 2 Superior Drummer 2.2 |
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! | Justin1524 | Eleven Rack | 0 | 11-27-2015 02:53 PM |
Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!! | quebecguitare | Eleven Rack | 1 | 09-01-2015 11:40 PM |
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
