Old 06-09-2021, 10:31 AM
Geoff_Mitchell Geoff_Mitchell is offline
Default S6 wishlist: copy/paste on strips?
Has anyone found a super fast way to copy/paste EQ (plugins settings) directly on the S6? The most efficient way I've found is to select EQ- then (soft key) copy plugin settings-select EQ - then paste settings. This involves channel strip selection and softkeys. Two different physical locations and 4 key strokes for a common move.
I'm finding it is not as ergonomic as some of the "older" consoles that would copy by holding EQ and then it would paste to next selected.
If a similar logic, or "in-strip" modifiers, could be integrated into the S6 for copy /pasting parameters it would be a big speed gain for us here post mixing.
Old 07-30-2021, 06:06 AM
creativecontrol's Avatar
Default Re: S6 wishlist: copy/paste on strips?
This continues to be one of the number one requests from mixers on S4 S6. ICON had a very basic implementation whereby a single plug-in (assuming it was identical in plug-in and width) could be copied from source channel via CMD + Shift while pressing Sel on a top level Insert. CMD + Shift while pressing BMP (the equivalent of In on S6) on one or multiple matching destination strips would perform the paste.
Customers often have similar processing on multiple like (dialog) channels and would benefit from the ability to copy one or multiple plug-ins from source to destination.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-30-2021, 09:34 AM
Postmh Postmh is offline
Which was originally on the system5. This feature is key for post-production. Am looking forward to the implementation on the s6/4.
Thx!
Old 08-02-2021, 03:28 AM
Gregor B. Gregor B. is offline
+1 on this
Old 08-02-2021, 04:29 AM
basehead617 basehead617 is offline
+1 for sure
Copy... Paste... Paste... Paste...? accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-18-2022 04:18 PM
Copy and Paste hntjr Pro Tools 10 2 10-23-2015 11:48 AM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
PT 5.1 can't copy and paste angelo panetta Tips & Tricks 2 03-22-2001 07:37 PM
