Old 01-28-2004, 12:59 PM
starlark starlark is offline
Default Digi 002 Inputs 5-8
I can't figure out how to use inputs 5-8 on my Digi 002. When I select an input for recording on a track, I only get a choice of inputs 1-4 (mono). What am I doing wrong?
Old 01-28-2004, 01:01 PM
stewie stewie is offline
Default Re: Digi 002 Inputs 5-8
you will need some kind of preamp for those channels.
Old 01-28-2004, 01:02 PM
Check your I/O Setup is correct.. load the defaults.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-28-2004, 01:12 PM
Thanks...I'll check the I/O setup when I get home. I haven't changed the setup since I got the system a month ago....i assumed the default was in place.
Old 01-28-2004, 01:36 PM
Andrew_k Andrew_k is offline
I thought channels 1-4 are mic. pres. & 5-8 are line inputs.
Old 01-28-2004, 01:44 PM
where02190 where02190 is offline
You are correct, 1-4 have mic pes', and can accept either line or mic level with a variable attenuation, inputs 5-8 are +4/-10 (switchable) line level only.
sound slike your i/o setup has changed.
Old 01-28-2004, 01:54 PM
Hi where02190,
Im recording some acoustic guitars at the moment, is there any down side to micing up the guitar using channel 1 (mic. pres.) & also using channel 5 just plugging the guitar from the pickup into the line input.
Cheers!
Old 01-28-2004, 07:15 PM
Not really, but you might try plugging the pickup into the channel two input, and utilizing the pad if necessary. this will allow you to adjust the amount of preamp gain necessary for optimum signal.
PT9 Not seeing inputs 5-8 on Digi 002 kennydmeek Pro Tools 9 4 09-07-2011 11:45 AM
having more inputs on DIGI 001 hyrobase75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-27-2006 06:31 PM
RCA inputs to digi 002. help? grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2005 09:21 PM
More inputs for digi 001 randyonbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-27-2003 04:58 AM
More Inputs for Digi 001? where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2002 12:35 AM
