Old 07-26-2002, 02:59 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac
for Pro Tools|HD for Macintosh Systems
Is now available from the Support/Downloads section in the following location:
http://www.digidesign.com/download/cs/531r2/
In order to use Pro Tools 5.3.1r2, you must first run the Pro Tools 5.3.1 installer, either from the Pro Tools 5.3.1 CD or the Pro Tools 5.3.1 download.
What's Fixed in Pro Tools 5.3.1r2?
This version contains fixes for the following problems found in Pro Tools TDM 5.3.1 for Macintosh:
  • <font size="2" face="Verdana, Arial">Assorted issues when using PRE in conjunction with ProControl & Control|24
  • <font size="2" face="Verdana, Arial">The Feet.Frames ruler was incorrectly calculated when session frame rate was set to 29.97
  • <font size="2" face="Verdana, Arial">Inserting silence into a MIDI track did not always displace automation data accordingly
  • <font size="2" face="Verdana, Arial">DirectConnect plug-ins or applications like Soft SampleCell and Native Instruments did not work with the 192 Digital I/O
<font size="2" face="Verdana, Arial">Who Should Use Pro Tools TDM 5.3.1r2?
This release has been fully qualified by Digidesign, and should be used by all Pro Tools|HD users on Macintosh-based systems, though if you do not use PRE, MIDI tracks, 192 Digital I/O or the Feet.Frames ruler, you will gain no advantage by updating from version 5.3.1.
Regards,
Digi Pro Tools Team
Administrator
Old 07-26-2002, 03:54 PM
michael c michael c is offline
Default Re: Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac
Is there a DigiStream version that has the lower "128" buffer for Direct Connect for this update? That is important!
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.7.5
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.12
HD Native Thunderbolt
Old 07-26-2002, 06:18 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
thank you digidesign
Chris Lambrechts
Applications Specialist- Live Sound
Old 07-29-2002, 10:32 AM
Stan Cotey Stan Cotey is offline
Hey,
Thanks Chris, for getting the word out faster than I did! I appreciate it mightily.
Stan
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid Pro Tools TDM Systems (Mac) 17 07-31-2002 06:24 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid Tips & Tricks 7 07-27-2002 04:58 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid ICON & C|24 0 07-26-2002 03:14 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid Post - Surround - Video 0 07-26-2002 03:00 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid General 0 07-26-2002 02:52 PM
