Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-04-2020, 11:12 AM
urban_spaceman urban_spaceman is offline
Default Mic not appearing in Audio Input Path Selector
Hi. My external mic (a Rode Podcaster) is not appearing in my Audio Input Path Selector.
I've selected it through: Setup > Hardware
nb at this point I'm thrown from PT to Audio MIDI Set Up, where I get a Audio Devices window. Here the Rode Podcaster is an option. I have clicked on it and selected "use this device for sound input".
nb the format is set to 44100.0 Hz which I've not changed.
My understanding that having done this the Podcaster should now appear in the interface list in Audio Input Path selector in the track ... but that's not happening for me, and I'm only seeing Built in Microphone 1 and Built in Microphone 2.
I'm using version 2018.7.0 on a Macbook Air 13 inch early 2014.
Would be massively grateful for your help.
EDIT
Update: I've tried selecting the Rode Podcaster as the Playback Engine (via Setup) but when I do this I am no longer able to open my project (it gets stuck on Getting Project Information), and infact I don't appear to be able to create a new project either.
Perhaps I should have also mentioned above that I'm using El Capitan v 10.11.6
Old 06-08-2020, 09:33 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Mic not appearing in Audio Input Path Selector
Try holding down the N key while PTF starts, which will reset the audio settings and prompt you with the Playback engine dialog. From there, make sure you choose the Rode as the playback Engine source. You should then be able to choose the input and output in the dropdowns below the main engine.
Once set, try creating a new project and add a new mono audio track. The new Mono track's input should default to the Rode.
Will
System Details
Old 06-08-2020, 11:25 AM
Top Jimmy's Avatar
Pro Tools requires an audio interface that has both an input and an output. The Podcaster is an input only device. The headphone jack onboard simply offers zero-latency confidence monitoring.
Use the Pro Tools Aggregate I/O and set up the appropriate ins and outs for it in audiomidi setup.
James Cadwallader
Old 06-22-2020, 07:15 AM
Amazing stuff, makes perfect sense, thank you :)
Old 06-22-2020, 10:35 AM
Top Jimmy's Avatar
James Cadwallader
How to select all "Audio Output Path Selector biuttons? briaboy Pro Tools 2018 2 04-09-2019 08:14 AM
Eleven Rack L/R not appearing in my input selector erniepaul21 Eleven Rack 5 12-07-2013 07:32 AM
Mic/Line 1 and Output 1-2 not showing up in audio input path selector gelianamrie Windows 4 08-02-2012 04:29 PM
Audio Input Path Selector can't see first paths. AlainZagar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-28-2010 10:05 AM
Mic/Line 1 not showing up in audio input path selector Artfuldodger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-29-2008 06:19 AM
