What's this? It's very annoying...
On all Digidesign RTAS VI GUI's.
In between the 'top' (main file loading and preset selection section) and 'bottom' (main GUI interface) there's always text that's not fully readable. It's always chopped in half. Looks like it's says "MIDI Notes: " etc. What's up?
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
Re: What's this? It's very annoying...
That is Midi node. It tells you what Midi channel the plug is set to. For example if you have four instances of Xpand each one would say Xpand 2, 3 and 4. It is a bit redundant as you can already see what midi channel that your on from the top of the channel strip.
I wouldn't mind if I could actually READ it instead of it being chopped in half. I'd post a pic but DUC don't allow it
Another annoying issue. A good issue, but still annoying. Plugin latency. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 05-20-2010 05:26 AM |
This is annoying | Audiofarm | Pro Tools TDM Systems (Mac) | 22 | 10-18-2007 08:46 PM |
Oh this is annoying | emilano | Tips & Tricks | 15 | 06-25-2005 04:35 AM |
relatively annoying bug in PT6.4 TDM | prismtheory | Pro Tools TDM Systems (Mac) | 1 | 06-03-2005 08:27 PM |
Annoying, annoying, annoying... error 2 | Anibal | Pro Tools TDM Systems (Mac) | 9 | 03-07-2003 02:20 PM |
