Help! Protools Won't install correctly
Hi, I'm just off the ground from a particularly aggravating case of reinstalling protools multiple times.
My problem started when I reinstalled my protools on my Macbook, it failed to install. Searching the forums I was instructed to install each piece of installation separately. Ok, that worked but with the new Mac operating system (OSX) Protools 9 is not compatible. This is where the problem occurs, first I chose the 9.0.5 patch that specifically dealt with this issue, then I separately tried patching 9.0.6. With both cases I got the same result: Failed to Install patch, then for some reason it deletes my Protools Application! So every time I try to patch and fail, I have to reinstall protools. I just want to get my protools working again, but I'm not sure what to do, any advice? I really appreciate any help! |
Will I be install & run both Protools 11 trial and Protools MP 9 in same laptop | bgeorge03 | Pro Tools 11 | 5 | 08-05-2013 06:19 AM |
Had to re-install OS - can't install protools | Hellbat | Eleven Rack | 2 | 11-27-2011 10:08 PM |
DVCPRO HD720 P24 Doesn't scale correctly in ProTools | Nathan W. | Post - Surround - Video | 1 | 06-07-2008 02:17 AM |
Protools Window WONT RESIZE CORRECTLY | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-19-2002 08:26 PM |
"ProTools did not shut down correctly" | writethis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-07-2002 06:47 AM |
