  #51
Old 09-14-2021, 02:15 PM
operator operator is offline
Default Re: *******Fix for Apple Security Update bricking displays*******
On the High Sierra partition everything is fine. It´s weird that only the MC Control causes this on Mojave. What sort of permissions could affect just this surface?
  #52
Old 09-14-2021, 02:29 PM
EddieJones's Avatar
Disk permissions maybe(I'm just guessing at this stage). Have you run Disk Utility and repair?
Are there any updates available to Mojave or are you on the latest?
Did I ask you to try with just on Monitor (if you had more than one)?
  #53
Old 09-14-2021, 02:36 PM
Yep, you did ask me to try with one monitor, but the problem persists. Disk Utility shows everything ok
  #54
Old 09-14-2021, 03:04 PM
Latest version of Mojave.
  #55
Old 09-14-2021, 03:26 PM
EddieJones's Avatar
Have you tried adding a new user and seeing if it still does it?
  #56
Old 09-15-2021, 07:14 AM
Hi Eddie, thanks for the suggestion. I just tried with a new user but the problem persists...
  #57
Old 09-15-2021, 10:34 AM
FWIW I`ve just done a clean install of Mojave / installed only EuCon. Problem persists...
  #58
Old 09-15-2021, 01:16 PM
EddieJones's Avatar
Does the screen on the Control come up and draw properly ?
  #59
Old 09-15-2021, 04:09 PM
The touchscreen is disconnected as it was faulty and emitting a high frequency tone. A replacement screen was not available because it was out of production.
Perhaps this causes a conflict in Mojave?
  #60
Old 09-15-2021, 04:18 PM
EddieJones's Avatar
Yes this could be the cause!
*******Fix for Apple Security Update bricking displays******* EddieJones Avid S1, S3, Dock and Control App 61 09-06-2021 11:52 PM
Do not load latest Security Update from Apple Park Seward macOS 5 03-12-2015 06:22 AM
apple security update 2009-002? nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2009 11:45 AM
OK To Do Apple Security Updates? hitshack Pro Tools TDM Systems (Mac) 3 11-30-2006 07:29 AM
Apple's security update is out, should i update? Arvid Gunardi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2003 09:00 AM
