Should I add a FW 800 Card to my Windows PC?
I just ordered the new Mbox Pro and the PT9 Cross-grade. I am upgrading from a USB Mbox 2 and PT 8 LE.
I am using a pretty old (2006) Dell XPS 400 and am in the process of adding a PCI card with 2 FW 800 and 1 FW 400 ports because I have read that FW is way better than USB 2.0. I was going over the system requirements for PT9 and saw where the FW cards were specifically recommended for MAC but wasn't mentioned for Windows based systems, am I reading too much into that? Is it ok to reconfigure my PC to use the 1394 FW card for better performance with PT or is that a bad move? Im not running Windows 7 (Im using XP Media Center - yes I know, not ideal), but I saw that the 1394 FW cards could have compatibility issues with Windows 7. I also need either an external hard drive or a separate internal hard drive to dedicate to recording... what is the best way to go and what are some good options? Obviously Im pretty new to the technical side of this, any advice is appreciated. Thanks! |
Re: Should I add a FW 800 Card to my Windows PC?
Make sure do the recommended system optimzations for XP. Your milege varies with Windows Media Center. I've never had problems. Others have.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Thanks. What specifically would be a good option on the hard drive?
The WD I mentioned is a SATA drive. You should have a look inside your machine to ensure it has SATA ports. If its an IDE Machine your choices are going to be pretty limited. I'm guessing however that its SATA.
From the pictures I've seen, the new Mbox Pro doesn't have any USB ports, only two FireWire. The Mbox is also FW400 so it won't benefit you to go 800 unless you're going to have FW800 devices in the chain, like an external HD.
Mbox 3 Pro iMac 27", OS X 10.6.5 Snow Leopard, Intel Core 2 Duo 3.06GHz, 4GB RAM, 1TB Internal, 3TB total External HD's Bye Bye Tascam and hello Pro Tools. It's been a long time coming |
Good call on the USB thing... forgot about that. As far as the 400 to 800... it is my understanding that the mbox pro ships with an 800 to 400 adapter cable, so in theory that shouldn't matter about having FW800 ports on the PC. The card I'm considering however, has 2 fw800 and 1 fw400.
PCI card causes freeze on Windows XP PRO SP2 w/ PT LE 6.4 | ladyelaine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-22-2007 03:46 PM |
Digi001 PCI Card not seen by windows | eledu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-20-2007 11:29 AM |
MJPEG-A card for Windows XP ? | MGalway | Pro Tools TDM Systems (Win) | 1 | 07-08-2003 06:09 AM |
windows doesn't know my card | Grysbock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2001 07:42 AM |
MixI/O card not windows? | Richard Fairbanks | Pro Tools TDM Systems (Mac) | 3 | 11-17-1999 08:04 AM |
