I cannot control-alt-delete. I cannot determine what exactly is causing this. It seems to happen when creating a new track, instantiating a new plugin, or bouncing to disk. The mouse ponter will freeze in the middle of the screen , and I have to manually turn off the computer by holding down the power button. does anyone know what could be causing this? I reinstalled the program, and now it seems only to freeze/crash during bounce. Thanks in advance.
I am inches from cubase.... |
Have you tried going back to 10.1?
Loading with no plugins? |
Dave911, to the rescue again. I will try this and report back tomorrow. I am using a lt of uad plugs... I wonder if they are causing the problem.
I had the same mouse and keyboard freeze in 10.2
I had to kill KORE from NI and a synth from XILS Labs I guess KORE has been trouble for some PT users before, (discontinued now anyway) the XILS one was always OK before. |
Male sure you do every single endows optimisation avid recommend. Windows aero played havak with PT I used to get loads of trouble untill I did this. I did do most of the optimisations but missed a few out. After going to their YouTube account and watching them all I realised there were a few I'd not done
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
It sounds like a hardware problem. Raoul just changed a card slot that fixed everything. i had a crash problem when I was using a tv tuner card but only on occassion. Protools may be unique in that it prioritizes things differently. An example is that when I forget to sync my apogee Mini Me to my Maudio 192, It still locks in never makes even the slightest pop and none of the waves are corrupt. It's amazing that they stay in phase or whatever ever it is in digital speak while unlocked. On the other hand, Cubase will have all kinds of pops and clicks when I forget to lock up. This makes me think that other audio software doesn't try to "own" the hardware like Pro Tools does. It isn't very convenient sometimes but when it works, it really works.
So when you have hardware conflicts in Cubase, it can let go of the hardware but you may be in there fixing a few waves but the program will chug along fine. If you get your hardware and interrupts happening in Protools, Cubase will run better too. A lot of people think that you can't have interrupt conflicts now with all the virtual interrupts but if you look at the interrupt list in Device Manager, you will still see alot of shared interrupts. Moving a card may make the system happier. |
Hardware problem? All I have is a MOTU Card and HD192, along with a UAD2 card. they are using my only 2 PCIE slots. Are you recommending swapping their slots? Thanks so much to everyone else. I will do all the optimizations I can today.
Ok. Once I tried doing the optimizations, the session was still misbehaving, but rather than taking the whole computer down, Windows was able to terminate PT. It turns out the problem was my uad plugins. As long as they were turned off, everything was smooth sailing. Once I turned even one one, the pro tools cpu meter went absolutely bezerk. It looks like I may have to take this one up with UA. Thanks so much for your help!
Try the slot swapping. It may not work and it is a pita but you could have everything smooth sailing. I had to choose to simply not use one of my slots or have intermittent trouble and have a tv tuner going. The tuner is waiting for it's own computer. TV does look nice on a computer.
OK I am seriously not trying to be a wise @#$. But judging from this thread I perhaps should NOT update PT10 to 10.2? I say this because while running the PT10 thirty day trial , I did install the 10.2 update and had to go back to PT9 due to the same issues I see described here. I have since purchased PT10 and am VERY happy , but am VERY leary about this 10.2 update. What does this update promise anyway that is worth the aggravation? Wonder if our pals on the MAC side have these problems?
Jerry |
Pro Tools not quitting properly, still active in Task Manager. | TheJamsh | Windows | 12 | 06-26-2012 08:32 AM |
Pro Tools 8 Task Manager frozen, won't do any tasks! | kingtinker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-09-2009 12:31 PM |
Pro tools shows up in task manager but does not boot | willl3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-20-2009 08:00 AM |
Task Manager | SKYHIENTERTAIN | Pro Tools TDM Systems (Mac) | 6 | 10-28-2008 11:13 AM |
Windows Task Manager Process | batchmister1 | Pro Tools M-Powered (Win) | 1 | 04-12-2006 06:26 PM |
